Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-08-2003, 11:24 PM   #1
STi-ll chillin'
Member#: 36124
2004 WRX STi
Silver/silver
Question Want to lower the front end. Advice?
I want to slightly lower the front end of my STi. Anyone got advice for me? What is the best way to lower it and have the least negative effect on ride/handling? Does anyone sell a kit/parts for this already?
I think the rear of the car is fine, but the front needs to be dropped a little.
(now putting on the flame-retardant jacket.........)
STi-ll chillin' is offline
Old 07-09-2003, 01:32 AM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Lowering the front relative to the rear is definitely going to have a detrimental effect on your handling.
ANZAC_1915 is offline
Old 07-09-2003, 01:39 AM   #3
FaastLegacy
Member#: 11671
Have you put dubs on your STI yet?
-faast
FaastLegacy is online now
Old 07-09-2003, 02:01 AM   #4
WRX Power
Member#: 7142
14 inch rims should help.
WRX Power is offline
Old 07-09-2003, 08:34 AM   #5
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
Let the air out of your front tires.
SkirtBoy is offline
Old 07-09-2003, 08:38 AM   #6
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Put more air in the back tires.
redobs is offline
Old 07-09-2003, 08:52 AM   #7
Pre-diddy
Member#: 26837
04 STi - Sold! :(
Raise the rear end
Pre-diddy is offline
Old 07-09-2003, 09:08 AM   #8
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Apologies for the serious post, but the front is supposed to look higher than the rear. It's not really, it's just that the fenders flare more in the front than in the rear.
It's part of the Subaru "look", so just enjoy your car's huge amounts of suspension travel, rather than screwing up your STi's handling to try to fix it
TimStevens is offline
Old 07-09-2003, 10:04 AM   #9
rhdude
Member#: 6637
2009 Acura MDX Sport
make your friend grap on your front tired
but really, on any stock subaru, the front sits higher than the rear from the factory... for a reason... if you drop the front, you need to drop the rear as well...
rhdude is offline
Old 07-09-2003, 10:51 AM   #10
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Most aftermarket lowering springs for the wrx tend to lower it more in the front than in the rear. I have my coilovers height set for a 2" drop in the front, and 1.5" in the rear - and my car handles better than an sti. So there is no reason the car can't have the front dropped more.
Prodrive wrx springs tend to lower the car much more in the front, there will be a very small drop in the back. I would think that they would also be a good match in spring rates, very similar to stock sti. Or you can wait for a prodrive sti spring, or any other aftermarket spring, or just get coilovers.
Kevin
Red Rocket is offline
Old 07-09-2003, 12:38 PM   #11
Jack(LA)
Member#: 37606
'04 STi
Being new to the Subaru WRX/STi ownership circle, I know I have a lot to learn so bear with me.
It would seem that there are some STi lowering springs available from Japan which are designed to fit and work with our '04 STi's (i.e., spring rates are supposedly compatible with stock STi shock/strut dampening). I've been told these springs will only slightly lower the car -- about 20mm front and rear. They are even the correct color.
Any thoughts/input on the use of these springs would be appreciated. Does anyone know if the ROW (Rest of the World)STi's have a lower stock ride height than the US cars, as is the case with most German made cars?
Jack(LA) is offline
Old 07-09-2003, 12:42 PM   #12
wrx what
Member#: 19697
2008 WRX STi
If your gonna lower, I would go with the JDM OEM Lowering springs...
wrx what is offline
Old 07-09-2003, 02:23 PM   #13
zacek
Member#: 19467
02 WRX
WR Blue
no, no, no the STi springs do no offer any noticeable drop nor leveling.
For the leveling loks and minimum drop wait for the Eibach springs, they are already working on them as per their website.
For a good moderate drop cutting that NASTY TIRE GAP and leveling definitely wait for the PRODRIVE springs for the STi.
(This is my CHOICE, however no news on when will they release such a product for the STi)
For an even more aggresive drop just wait for the TEINS.
zacek is offline
Old 07-10-2003, 07:04 PM   #14
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
The black stock springs do not. The pink aftermarket ones (shown above) do lower but I believe that they lower an equal amount front and rear. Springs for the 02/03 WRX will not work on the STi unless you replace the rear strut tops.
driggity is offline
Old 07-10-2003, 08:22 PM   #15
Z1 Performance
Member#: 9327
There are currently no springs in Japan for the revised GDB, which is what your chassis code.
For any springs for your STi, from Eibach, to H&R, to STi and others, you will need to purchase the springs, as well as the rear upper mounts for an '02-'03 WRX (you can either get the stock OEM mounts, or the STi Group N units). this will allow you to use any of the springs for the '02-'03 WRX all of which would work nicely with the struts in your STi from the factory.
Z1 Performance is offline
Old 07-10-2003, 10:13 PM   #16
STiLL WILL
Member#: 37581
2004 SZ55'd STi
375whp on 91/404whp on 95
Default coilovers?
Will any of the high end coilovers(JIC, TEIN, DMS, HKS, APEXi, etc...) currently on sale for the WRX work on the STi?
-STiLL
STiLL WILL is offline
Old 07-10-2003, 10:35 PM   #17
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Yes, but you'll probably have to use old style top mounts in the rear if the coilovers don't come with their own.
driggity is offline
Old 07-11-2003, 01:16 AM   #18
Z1 Performance
Member#: 9327
Correct - anycoilvoer that includes rear upper mounts (ie camber plates or pillowball mounts) will work great!
Old 07-11-2003, 01:24 AM   #19
somebody else
Member#: 21618
Hey, back off, folks!
It's his car; he can ruin it any way he wants. If he values looks over performance -- forgetting for the moment that most "looks" have their roots in performance -- well, have a rice day.
Personally, I'd opt for green and orange hubcaps that spin and have neon -- less of a performance hit.
--scott
somebody else is offline
Old 07-11-2003, 02:07 AM   #20
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
I have a 2002 WRX with STi struts and STi lowering springs (pictured above). My car dropped about 1" front and rear and now sits to my liking. The front is still higher than the rear, but it's bearable to look at now.
-Bob
dookiebob is offline
Old 07-11-2003, 02:25 AM   #21
WorldOne
Member#: 22731
2002 WRB Do-Luck GDA
worldoneperformance.com
Our customers have installed successfully the Tein Flex system with EDFC for the 02-03 WRX, and just like mentioned previously, since these dampers include new topmounts the fitments is great.
Other customers have installed the H and R system. Although this system does not include top mounts, STi top mounts from 02-03 quickly remedy the problem and our customer is reporting that he is thrilled with his set up.
Finally a customer installed a set of Cusco Zero 2's and they work great as well. All of these are great options.
As a side note, although a system with height adjustability will allow you the opportunity to lower the vehicle in the front more than an in the rear to eliminate wheel gap, this will have adverse effects on handling. Even with a height adjustable system you want to make sure that you lower all four corners the same, therefore the front will always look higher than the front to a degree.
Cheers,
Garret
World One
www.worldoneperformance.com
[email protected]
WorldOne is offline
Old 07-11-2003, 02:32 AM   #22
STiLL WILL
Member#: 37581
2004 SZ55'd STi
Thanks for the good Tein info WorldOne! I got a question, what are the main differences between the Tein SS coilovers and the Tein FLEX coilovers? Also, do the SS's come with topmounts as well?
STiLL
Old 07-11-2003, 02:36 AM   #23
liigod
Member#: 30512
01 2.5rs
black
boost fluid or muffler bearings should do it.
liigod is offline
Old 07-11-2003, 11:30 AM   #24
Z1 Performance
Member#: 9327
The SS and Flex both include pillowball upper mounts front and rear for the WRX, and they are both camber adjustable in the front (for rear camber, we supply camber bolts for all coilover purchases). Both are also 16 way dampening adjustable, and both can accept the EDFC module for allowing dampening adjustment from inside the car. The Flex has an adjustable lower bracket, which basically allows you to do your main rideheight adjustments by adjusting the length of the strut body itself. This allows you to adjust rideheight, keep spring preload at a minimum, and also not affect the stroke (or travel) of the shock.
The SS is the replacement for the HA. While it has pillowball mounts front and rear, you can only adjust rideheight by adjusting preload the spring (via the lower spring perch). So, as you lower the car you are also reducing suspension travel. For a car that is mainly street driven, with occassional autocross or track use, the SS is more than enough. Nicest feature about it IMHO is that the pillowball mounts do not seem to suffer from the same knocking noise as the Flex's tend to when installed on a WRX (Will - if you are new to these forums, just do a search for "clunk Tein and Flex" in the suspension forum...it has been discussed to death, and is basically an issue with the bearing tolerances in the rear mount of the Flex). Its basically a crap shoot with the Flex, as 50% of the installs we do get it, 50% don't. By comarison, I have yet to install an SS on a WRX that had any clunk whatsoever..same goes for the RA (also Tein), as well as the JIC FLTA2 and Cusco Zero 2's.
Other units worthy of consideration, depending on your budget, are the Tanabe's (they have a good set of offerings, and very capable, adjustable units), as well as HKS (easily the most adjustable, but at the higher end of the price spectrum), as well as Zeal.
Adam
just put lowering spings in my 2008 2.5 impreza but now the front end is knockin!!! peno General Community 6 12-30-2008 09:13 PM
Want to Convert My 02 Bugeye to 04-05 Front end. KassanovaSTi Interior & Exterior Modification 74 07-04-2008 10:28 PM
anyone with an 04/05 want to trade their front end for a bugeye? skate enjoi Exterior/Styling 6 02-24-2007 04:35 AM
Want to plant a tree in the front yard. Advice? Layman Off-Topic 35 03-08-2005 01:17 PM
Lowering the Front End TurboRex Brakes, Steering & Suspension 9 09-13-2001 11:31 AM
