Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 01-15-2001, 01:35 AM   #1
CHRISSVX
Member#: 3564
Post my car whines
i have a rumbling /whineing sound that is coming from what seems like the area of the wheels, its constant and increases with speed.i have had the gear box checked and found faultless and wheel bearings checked also faultless(HELP!!!!)THE SOUND IS DRIVING ME MAD AND SPOILS A VERY GOOD CAR.ARE THERE ANY QUIRKS THAT WOULD FOOL A MECHANIC INTO THINKING THAT THE SOUND IS COMING FROM ONE PLACE WHEN IT IS REALY COMING FROM SOME PLACE ELSE!(HELP).
CHRISSVX is offline
Old 01-15-2001, 04:51 AM   #2
richeich
Member#: 1353
2001 Impreza 2.5RS
Unhappy
Unfortunately, it's a common failure on the SVX. You've probably got a bad wheel bearing.
Rich
richeich is offline
Old 01-15-2001, 06:49 PM   #3
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post
Agreed, sounds like a bad bearing. If the sound gets louder at higher speeds, then it is most likely the rear wheel bearings. Are you sure they checked out okay? I had an annoying sound on certain kinds of pavement that was worst at around 30-35 mph and went away at higher speeds- both the mechanic and I thought it was the wheel bearings, but it turned out to be the tires.
Glen
glenstiles is offline
Old 01-15-2001, 07:16 PM   #4
CRZ_MSL
Member#: 1610
Post
If it is coming from the front of the car it may be your transmission.
If it is coming from the rear of the car, it is most certainly your bearings.
Time for an offering to the Parts Gods
CRZ_MSL is offline
Old 01-15-2001, 08:16 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
I had a noise on my Legacy GT that made me think the rear diff was bad. Just for grins I rotated the tires (back to front, front to back), and bingo, the noise moved to the front. New tires fixed the problem.
Another way to troubleshoot would be to feel your wheels after you've been driving(especially highway). The hottest wheel could be your cuprit. Brake dragging, wheel bearing, somthing along those lines. I had the parking brake on the drivers side hang up on my SVX (which is a drum type setup within the disc brake), and that's how I figured it out.
Good luck-
Rich
(sorry for the short reply earlier- it was early)
richeich is offline
Old 01-15-2001, 09:20 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
And to think, I was going to ask if your g/f or wife was in the car... :0
kastle is offline
Old 01-16-2001, 04:07 PM   #7
1994subarusvx
Member#: 3358
Unhappy
my car makes a pop on the right front when i brake really hard or sometimes when the car finally comes to a stop there is a pop? more svx bs! this car is my money pit! also sometimes when i am driving and the accelerate is depressed, say i am cruising around 50mph, and then i suddenly let of the gas there is some kind of disengagement of shutter, almost like if i let out the clutch or something... i just recently had the transmission replaced so what could it be?? please help....i am scared....ok that sounded weak.....lets just say i am concerned.
1994subarusvx is offline
Old 01-16-2001, 06:00 PM   #8
CRZ_MSL
Member#: 1610
Post
If you are waiting for us to attack you for calling the SVX a money pit... keep waiting.
I think we all agree that it is a money pit for sure. The good part is that we know exactly what corners of the pit (bearings/transmission) to throw our money in to.
$$/(s)mile, you will be hard pressed to find a better deal.
If your transmission is "kicking" when you let off the gas, have your SVX mechanic take a look at the band-brake on your transmission. Adjusting the band brake effects how the car shifts up under acceleration, shifts down under deceleraion. I just found out how to adjust it over in the powertrain forum, I am having similar problems to yours-- but I have about 90,000 miles on my current transmission.
Not 90K on the car, that's 90K on just the transmission alone
[This message has been edited by CRZ_MSL (edited January 16, 2001).]
CRZ_MSL is offline
HTML code is On
my car developed a whining noise (it is RPM dependent) dubya-R-ex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-16-2007 05:06 PM
[Whine]I'm never going to find a good car[/whine] BigWrecKs Off-Topic 51 07-04-2006 02:25 AM
experiencing whining :( is my car gonna blow up bosozoku Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-14-2004 07:24 PM
My car whines shortly after tranny rebuild! jdsimpreza Transmission (AT/MT) & Driveline 5 09-16-2003 11:56 PM
more n00bness OR my car makes a whining sound! mr_yellow Normally Aspirated Powertrain 12 09-15-2003 07:27 PM
