#1 |
Member#: 10921
Vehicle:04 04 STi 12.8 @ 105 mph |
I was looking to reduce some weight in my STi. I took out the spare tire and the jack and weighed them. Together they weigh a large 42 lbs.
On average they usually say that 100 lbs is equal to 10hp. I believe its a little more than that with a WRX. In my stage 4, 02WRX, reducing weight really helped performance. I think I'm going go without my spare around town and at the track. If I go for an out of town cruise I'll put the spare back in. 42 lbs is a nice weight reduction.
#2 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
A drop of 42 pounds is worth the price of AAA+ membership, many benefits to AAA+ but the main one is 100 miles of towing to ANY location you choose. 3 times a year! Plus free duplicate keys (plastic) and DMV window inside that is rarely busy.
#3 |
Member#: 35735
Vehicle:2005 STI Aspen White |
That is great weight savings...
Now if you could move some weight from the front to the back to offset losing weight off the rear wheels... |
#4 | |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
#5 |
Member#: 10921
Another thing I forgot about is the exhaust. When I took the stock exhaust off my WRX and compared it to the turbo back exhaust I got from Turboxs, there was a big difference in wieght. The factory exhaust is very heavy. There is probably a 10-15 lbs difference between Turboxs's exhaust vs the stock STi exhaust.
I should call turboxs and ask them how much lighter their turbo back exhaust is. If it is 10-15lbs total, which is very realistic + 42 lbs from removing the spare and jack. That will be over 50lbs of weight off the car. |
#6 | |
Member#: 33246
Vehicle:1993 Legacy L+ AWD Phoenician blue met./blue |
I'd asked so many new STi owners to weight their spare & jack yet I was totally blown off. I'm glad to see someone finally sees the light. I'm going to do the same and invest in Fix-A-Flat and a a rescue service fro Costco ($29.99/year!). I plan to go with a lighter weight/higher cpacity battery as well as any other easy/quick weight reduction mods I can find/think of. Coming from a track & field as well as cycling background, I know the quickest & easiest way to gain speed is to drop the fat. ![]() Swing by your friendly neighborhood parts man and see if he can get you a weight of the exhaust can. I'm sure anything made from titanium will be _much_ lighter. Good info... - Janq |
#7 |
Member#: 33424
NESIC
Vehicle:2004 STI Blue/Gold |
Just a little FYI, you may not care, the spare tire is part of the rear crash zone and designed to absorb some of the impact in the event of a rear end collision.
#8 | |
Member#: 8351
Vehicle:2002 WRX Wagon |
Anyways, my weight reduction scheme is mostly focused on things that are _relatively_ easy to reverse and won't significantly pose a safety problem: gut trunk ~ 44lbs lite weight battery ~ 15 lbs racing seats ~ 25 lbs (depending on $$$) exhaust ~ 15 lbs (more with titanium) remove A/C compressor and condenser ~ 30 lbs (more?) Around 120-130lbs can be dropped with most expense going towards an exhaust and seats. There are lots of other little things to do, but they can be a pain to do. There are a couple of threads floating around with WRX weight reduction schemes. TRS Last edited by ToddStratton; 07-09-2003 at 11:23 PM. |
#9 | |
Member#: 33246
- Janq |
#10 | |
Member#: 33270
NWIC
Vehicle:2004 STi WR Blue |
#11 |
Member#: 32576
Vehicle:04 STI Roller Barrel ITBS |
Please don't think that the spare tire would save you in a rear impact crash. That tire is only held into the bay with a tiny 1/4" size bolt. In a crash, it would be the same as having random junk in your trunk = no benefit. The frame (rigidity) is what makes the cars safe not a spare tire.
| Thread Tools | |
| Display Modes | |
| Mikaust Retune - TurboXS GT30 .82 Kit & Andrewtech Motor build! 561whp & 489 ft. lbs | Imprezd | Proven Power Bragging | 70 | 06-20-2008 10:17 PM |
| WTB: 2.5RS Cats, Trunk, Spare & Jack | 96stangGT | Private 'Wanted' Classifieds | 6 | 04-09-2008 08:14 AM |
| Fs - 2004 Sti Spare Wheel/tire & Jack Kit - Never Been Used | mazdman | Wheels/Tires | 1 | 04-01-2007 08:32 AM |
| WTB: Spare tire jack "spinner" & WRX pedal covers | Siper2 | Mid Atlantic Impreza Club -- MAIC | 4 | 05-10-2005 10:07 AM |
| FS: Bumper beam, spare tire, jack | no pressure | North West Impreza Club Forum -- NWIC | 13 | 03-31-2005 12:17 AM |
