Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-09-2003, 08:40 PM   #1
WorldOne
Member#: 22731
2002 WRB Do-Luck GDA
worldoneperformance.com
Default STi Max Boost: How high are you getting?
Hi there folks...
I am creating this thread to document boost annomilies that many of us our experiencing. In order to post in this thread, I would appreciate if you could include the following information.
1. Gauge that you are reading boost with (electric v mech)
2. Peak Boost Reading and Units (Bar v psi v kg/cm^2)
3. Gear in which peak boost achieved
4. Hold till redline or tapers off
5. Detonation? (yes or no)
6. If you have a PWH gauge include photo of peak boost on gauge)
I will start:
1. Greddy 60mm PWH Electronic.
2. 1.2kg/cm^2 = 17.1 PSI according to tool below.
3. 2nd and 3rd
4. Holds till Redline
5. Yes!
6. Will add pic shortly!
Coversion tool: http://www.ex.ac.uk/cimt/dictunit/ccpress.htm
Hopefully this thread will shed some light on the magnitude of the discrepencies that some of us our experiencing and educate us about our cars in the process!
Thanks for your participation!
WorldOne is offline
Old 07-10-2003, 03:38 AM   #2
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
1. SECS PSI^3 data display. Reads boost and peak boost(and other stuff) from ECU
2. 15.1psi
3. 2nd and 3rd and 4th i think
4. tapers
5. no, 91octane
6. will take photo soon
StealthWagon is offline
Old 07-10-2003, 08:03 AM   #3
strangerq
Member#: 13095
Just a bit of history/warning.......
you will encounter the issue of aftermarket boost guages with custom installs, and to what degree readings can be trusted.
17 psi is really high. your car must be an absolute rocket.
strangerq is offline
Old 07-10-2003, 08:17 AM   #4
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
I'm hitting exactly 1 bar (14.5 psi) on my Defi BF. When it's warmer out it seems like boost is slightly reduced
ha-evolution is offline
Old 07-10-2003, 08:24 AM   #5
happasaiyan
Member#: 37731
1. defi bf
2. 1.1bar
3. 3, 4, 5, and 6
4. tapers off to 1.0bar
5. no
6. ill post later today.
happasaiyan is offline
Old 07-10-2003, 01:12 PM   #6
WorldOne
Member#: 22731
I completely understand about the variances associated with custom mounted boost gauges and all other methods of measuring boost. For this reason I tested the reading with a separate boost gauge and recieved the same results.
1.2 kg/cm^2 is the absolute maximum boost that the car will achieve and this does not happen all the time. 1.1 kg/cm^2 is a regular occurance and easily achievable in every gear.
The cars natural tendency in anything less than 100% throttle is to taper the boost as you guys have mentioned. However if the gas pedel is pegged to the floor no such taper occurs.
My results are similar to those noted by the Turbo XS car and we are not sure of the cause at this time.
Thanks for reading.
WorldOne is offline
Old 07-10-2003, 06:44 PM   #7
happasaiyan
Member#: 37731
i know for a fact mine tapers. when im running on down the highway at WOT, i hear the boost buzzer go off (i have mine at 15.5psi), then it will turn off at around 6k rpms. and yeah, my foot is all the way down.
Income Tax Return time: How much are you getting back? txl146 Tri-State Area Forum 49 02-01-2007 11:26 PM
How high can you get the boost in first gear, large turbo owners speak up!!! jared nelson Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 10-24-2005 01:37 PM
wrx's w/lightened flywheels: how OFTEN are you getting misfire codes? legacy2003 Transmission (AT/MT) & Driveline 10 10-13-2005 01:01 AM
how many kilometers are you getting on a full tank? mugsy Canada Region Forum 20 05-08-2003 01:11 PM
how many miles per tank are you getting STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-09-2002 10:54 PM
