Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 01-19-2001, 08:45 AM   #1
CRZ_MSL
Member#: 1610
Talking Tire pressure
FOr the entire time I have owned my SVX I ran my tires at 32psi/32psi. Then while doing a pressure check I noticed that the current tires have a max psi rating of 45, so I bumpred the pressure up to 42psi all around (to allow wiggle room due to thermal expansion)
WOW!!!! It was SCARY-FUN how fast I could dive into those curves with my foot on the gas. This simple mod (does it count as a mod?) did so much to change the handling of the car.
Naturally, the ride is quite bumpy, but any passengers who don't like it can walk.
CRZ_MSL is offline
Old 01-19-2001, 11:43 AM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
What brand and size are you running?
kastle is offline
Old 01-19-2001, 08:24 PM   #3
CRZ_MSL
Member#: 1610
Smile
I think they are Goodyears, unidirectonal V-rated.
I have head that Subaru changed the factory spec air pressure for the later year cars. I have run equal pressure front/back for most of the time I have owned my SVX. I think the original pressure specs were made with comfort/ride quality in mind, not handling-- sort of like the borderline underinflated Firestones on the Ford SUVs. Higher pressure = better response, but harsher ride.
CRZ_MSL is offline
Old 01-20-2001, 12:02 AM   #4
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Post
How does this affect the rolling circumference? Factory spec is 33/29, when my tire pressure is off I notice a slight rumble strip effect at high speeds, feels like the front and rear are fighting eachother. I figured it was the speed sensors showing a difference in speed front to rear due to the different rolling circumference caused by low tire pressure. This is my warning that the tires are getting low. It goes away instantly when I air them back up to specs.
immortal_suby is offline
Old 01-20-2001, 07:12 PM   #5
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post
What is factory tire pressure spec for the later SVXs? I run what the door sill plate says- I think its 33/29. This is on 225/50/16 tires. While we are talking tire tech... Anyone think of running a slightly smaller aspect ratio like 215/50/16 or 225/45/16 to help acceleration on our tall-geared cars? Just a thought...
Glen
glenstiles is offline
Old 01-20-2001, 11:45 PM   #6
CRZ_MSL
Member#: 1610
Post
It would likely help acceleration, and be much cheaper than a gearset change.
The down side is this: Your SVX will sit closer to the ground. I think my SVX sits a bit too low to the ground to begin with. I't VERY irritating to park next to a curb, and find myself unable to open the passenger side door because the door sill is lower than the curb is tall.
CRZ_MSL is offline
Old 01-21-2001, 07:18 AM   #7
immortal_suby
Member#: 1711
140 rogue points!
Post
The 97 svx stock tire size was 215/55. changing to this size is a 1.8% difference. there's a cool toy at this website to calculate tire sizes and their effect -
http://www.miata.net/garage/tirecalc.html
Old 01-22-2001, 09:50 PM   #8
glenstiles
Member#: 2827
2002 WRX wagon
Post
When my tires wear out, I'm gonna try Kumhos in size 225/45/16. This is a little shorter than stock by 3.5%, and the sidewall is about half an inch shorter. I figure that the pros of slightly better acceleration and less sidewall flex would offset the lowering affect and having the speedo read a little high. 225/40/16 is also available in the Kumhos but may lower the car too much, ie. lowrider look...
Glen
HTML code is On
what tire pressure to run stock? and what is a good aftermarket tire? jay25RS Tire & Wheel 6 06-13-2011 01:54 PM
New tires, which tire pressure to go by, tire or car? NewShockerGuy Tire & Wheel 7 12-04-2004 02:33 PM
Tire pressures for snow tires? TimStevens Brakes, Steering & Suspension 10 12-22-2001 05:00 AM
Tire Pressure Loss on Yokahoa Geolander Tires Rusty Russell Forester Forum 1 08-04-2001 03:00 PM
Tire Pressure for snow tires??? 99 RS 2.5 New England Impreza Club Forum -- NESIC 4 10-12-2000 09:17 PM
