Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-09-2003, 11:52 PM   #1
Triple S
Member#: 39300
'04 STI
Silver on Silver
Default What does your STI boost read?
My boost is supposed to be 1 bar or so I thought. I only makes it .8 of the way? What does your's boost do? Do you have any explanations for this?
Does the stock gauge register pounds of boost or bars? Are these stock boost gauges accurate?
Triple S is offline
Old 07-10-2003, 01:57 AM   #2
Quickshift
Member#: 32819
2003 WRX
WR Blue Pearl
My boost is supposed to be 1 bar or so I thought. I only makes it .8 of the way? What does your's boost do? Any explanations?
that could have something to do with the gear you're in. I'm not sure about sti's, but the wrx's boost level is limited to lower levels by the factory boost controller in 1st and 2nd gear.
Quickshift is offline
Old 07-10-2003, 02:48 AM   #3
Mach5WRX
Member#: 17060
1.1 BAR in 3rd, 4th & maybe 5th. I'll go check and post up later.
Mach5WRX is offline
Old 07-10-2003, 03:16 AM   #4
Jimmy S.
I'm a real doctor
Member#: 11271
Default Re: What does your STI boost read?
press the gas pedal to the floor in fifth and then tell me what it reads.
-SF
Jimmy S. is offline
Old 07-10-2003, 03:21 AM   #5
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
I've had peak boost pressures of 15.1 psi on a few occasions, i need to test a bit more to see if it is just spikes, and where it occurs the most.
StealthWagon is offline
Old 07-18-2003, 10:38 AM   #6
Triple S
Member#: 39300
'04 STI
Silver on Silver
Default Re: Re: What does your STI boost read?
-SF [/b][/quote]
As soon as I can put my car's interior back together into a driveable state, I will press the pedal to the metal and see what I get.
Triple S is offline
Old 07-18-2003, 10:46 AM   #7
happasaiyan
Member#: 37731
1.1 bar...
check your connections...
happasaiyan is online now
Old 07-18-2003, 11:28 AM   #8
Triple S
Member#: 39300
'04 STI
Silver on Silver
Originally posted by happasaiyan
1.1 bar...
My boost gauge is the stock factory gauge. What connections should I check? Should I roll it into the dealership and ask them to check the connections?
Triple S is offline
Old 07-18-2003, 11:39 AM   #9
Hummer
Member#: 31892
2004 STi
15 psi max boost with Perrin short ram and TurboXS RFL-TI.
Hummer is offline
Old 07-18-2003, 11:51 AM   #10
Triple S
Member#: 39300
'04 STI
Silver on Silver
In what gear and at what point in the RPM range?
Triple S is offline
Old 07-18-2003, 12:31 PM   #11
STi&LT1
Member#: 36645
I hit 17.1.
STi&LT1 is offline
Old 07-18-2003, 12:46 PM   #12
mazdman
Member#: 28506
2005 STi
White/Gold
15.8 psi (bone stock)
mazdman is offline
Old 07-18-2003, 12:50 PM   #13
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
1 bar on the Defi BF in all gears except first. I did notice this morning that I got another .05 bar because it was cooler than usual.
ha-evolution is offline
Old 07-18-2003, 01:51 PM   #14
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I hit 17.5 and get engine cut during long full throttle runs in 5th (on the track).
The ECU cuts engine power when it sees 17.5psi for over 2 seconds. I got this numerous times on the track with a Turbo-Back Exhaust and silencer hack.
Russ
rlavalle is offline
Does your MP3 player read your thoughts? BlkTS02 Off-Topic 3 04-06-2006 11:46 PM
What does your cockometer read? snyper Off-Topic 3 02-19-2006 11:31 AM
what vacuum level does your stock boost gauge show at idle rocketwrx Newbies & FAQs 7 02-06-2006 09:45 AM
what does your STI idle at? probably Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 11-02-2004 03:30 PM
What does your oil pressure gauge read? AWDTalon92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-02-2003 11:14 PM
