Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-09-2003, 11:54 PM   #1
skeisenb
Member#: 2556
2000 Legacy GT Sedan
Black Granite Pearl
Default brakes
What is the proper order to bleed the brakes on my 2000 legacy? I have a stock ABS brake system.
Also, how much brake fluid will it take to bleed out the whole system?
skeisenb is offline   Reply With Quote
Old 07-10-2003, 12:21 AM   #2
legacy2003
Member#: 38338
2003 Outback Sdn H6
Smile bleeding brakes
i had to bleed my stock abs brakes on my 95 when i lowered it because i had to take off the brake lines to pull the struts out. i didn't follow any particular order when i did it; i think we may have done the left front first, then right front, and then moved to the rear. as far as how much brake fluid you'll need, i couldn't tell you. i don't think it's that much, i think when we refilled it after we used 1 container. hope this helps.
legacy2003 is offline   Reply With Quote
Old 07-10-2003, 12:26 AM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
legacy2003:
Wrong. I have installed 18 struts on subarus (dont ask about the odd number) and never opened the lines. Use a hacksaw to open the brackets. Bend it out of the way. Do the same on installation.
Old 07-10-2003, 12:31 AM   #4
skeisenb
Member#: 2556
Black Granite Pearl
I believe there is a proper order when flushing the system to minimize contaminating new fluid with old fluid. Normally it is recommended to start with the furthest wheel from the master cylinder first and get closer and closer. But with ABS I think it is different. For a WRX it is RF, LR, RR, RF or something like that. I imagine the Legacy is has a similar brake system.
I need to find out what the proper order is for the Legacy
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS MWSOC Vendor Classifieds 10 09-10-2007 10:43 AM
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS Suspension/Brakes/Handling 10 08-13-2007 01:43 PM
Brakes Brakes Brakes cool13b Legacy Forum 2 03-22-2002 05:08 PM
Brake Lines, Brake Lines, Brake Lines: Rate malaki Brakes, Steering & Suspension 0 05-03-2001 06:55 AM
brakes! brakes! brakes! greg Mid West Subaru Owners Club Forum -- MWSOC 16 12-07-2000 08:36 AM
