Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 03-24-2001, 03:48 PM   #1
CHRISSVX
Member#: 3564
Wink Wheel bearings
Hi guys had a strange (x-files esk)experience with my baby. After putting up with a I,m a wheel bearing about to die sound for 5 weeks and replacing 1 full transmission I came to the conclusion that I would have to sell my wife and kid to pay for four wheel bearings when I hit a curb taking out drivers front and back tyres,leaving only one choice which was to change all tyres, hey presto no more wheel bearing sound Yokohamas off Continentals on.PS any advice on new front shocks.
CHRISSVX is offline
Old 03-24-2001, 11:36 PM   #2
CRZ_MSL
Member#: 1610
Post
For front shocks I suggest that you try the Subaru OEM. Or you could try the Subaru OEM, the Subaru OEM are good if you are going to replace the rear struts at the same time, but if you are going to do the fronts only, I suggest the Subaru OEM.
The choice of chocks for the Subaru has slightly more variety than your choice of sunlight.
CRZ_MSL is offline
Old 03-27-2001, 05:03 PM   #3
rhhnx
Member#: 1634
Post
Since replacing all 4 tires with yoko AVS dB the car has never been quieter. Had just replaced both rear bearings too, which accounted for some of the noise, but it seems a lot of noise I blamed on bearings was from the tires.
Tires used in past:
OE bridgestones (were also quiet)
Michelin Pilot
some cheap Yokos cheap but good, however noisy
goodrich comp t/a vr 4 (best tread life)
ads says bridgestone turanza also supposed to be quiet
rhhnx is offline
HTML code is On
Wheel Bearing or Diff Carrier Bearing? flyingtaco Transmission (AT/MT) & Driveline 12 08-30-2009 02:49 PM
Wheel bearing removal: disintegrated wheel bearing eurojax Brakes, Steering & Suspension 4 06-23-2009 11:28 AM
FS: Wheel Bearings w/seals. Prepacked with Neo HP800 Bearing Grease Gro Harlem Suspension/Brakes/Handling 9 03-04-2009 11:35 AM
Wheel bearing vs wheel bearing assembly? Trin_Starr Legacy Forum 2 10-19-2006 09:42 AM
are front wheel bearing on Impreza'a press in bearings? Homemade WRX Transmission (AT/MT) & Driveline 7 10-22-2004 10:33 AM
