Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-10-2003, 09:29 AM   #1
calworld
Member#: 5711
2004 STI
Default Will anybody with STI strut bar kind enough to post a pix?
I already try to fit it but it won't fit without modification
I did a search and find some description about the modification
but I am not quite sure what to do cause I am not a good interpreter. Can somebody kind enough to post a pics since pix do wonders for me.
Thanks in advance
calworld is offline
Old 07-10-2003, 10:26 AM   #2
STi&LT1
Member#: 36645
Front or Rear?
STi&LT1 is offline
Old 07-10-2003, 11:13 AM   #3
calworld
Member#: 5711
2004 STI
Front
thanks
calworld is offline
Old 07-10-2003, 11:26 AM   #4
STi&LT1
Member#: 36645
I can post a pic tonight...but it is really simple, there is only one thing that has to be moved, there is a bracket on the drivers side that is held with two bolts, take out the two bolts and then move the bracket down. This means the brackets top hole will go into the bottom hole of the firewall. once that is done install the bar, and gently tweak the ac lines to insure no rubbing. your done.
STi&LT1 is offline
Old 07-10-2003, 04:02 PM   #5
sube151
Member#: 3184
00 Grp N Wrx STi,
+99 V6 STi,
sube151 is online now
Old 07-10-2003, 04:11 PM   #6
STi&LT1
Member#: 36645
this should give you a good idea of what you have to do
STi&LT1 is offline
Old 07-10-2003, 04:16 PM   #7
STI 2 NV
Member#: 31748
'15 WRB WRX
looks good. who makes that bar?
STI 2 NV is offline
Old 07-10-2003, 04:53 PM   #8
STi&LT1
Member#: 36645
both of those are STi bars, the top photo is the Titanium bar, the bottom photo is the CF bar.
STi&LT1 is offline
Old 07-10-2003, 05:20 PM   #9
HOKWRX
Member#: 5469
2004 Impreza
Where is the horn now?
HOKWRX is offline
Old 07-10-2003, 05:43 PM   #10
STi&LT1
Member#: 36645
The horn is behind the grill in front of the radiator...where it always was....
STi&LT1 is offline
Old 07-10-2003, 06:25 PM   #11
sube151
Member#: 3184
00 Grp N Wrx STi,
+99 V6 STi,
I did the same "mod" to the A/C line. Works perfect.
Old 07-10-2003, 08:50 PM   #12
calworld
Member#: 5711
2004 STI
So, you HAVE to move the AC line to make it fit?
Just wondering...I will try it tomorrow
Thank you very much ALL
calworld is offline
Old 07-10-2003, 09:24 PM   #13
rallykeith
Member#: 34989
06 2.5i wagon
88 RX
He probably doesn't have the subaru upgraded security system. With the Subaru Upgraded security system they hang a horn off the passenger's side strut tower that looks like it would need to be relocated.
Keith
rallykeith is offline
Old 07-10-2003, 09:27 PM   #14
calworld
Member#: 5711
2004 STI
Keith
Since I got the upgraded security, so where should I relocate the horn?
Thanks
calworld is offline
Old 07-10-2003, 09:41 PM   #15
sube151
Member#: 3184
00 Grp N Wrx STi,
+99 V6 STi,
On the passenger side shock tower, you will see a hydraulic line
midway from the top. Take the alarm horn out of its metal hanger (12mm bolt). Unscrew the 12mm bolt that holds the hydraulic line in place, and screw it back in with the horn. The wire reaches perfectly.
Old 07-11-2003, 11:25 AM   #16
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Sube, that's one really clean engine! Is your STi brand new or have you been doing work to keep it that clean? If so, what?
essogas is offline
Old 07-11-2003, 01:17 PM   #17
sube151
Member#: 3184
00 Grp N Wrx STi,
+99 V6 STi,
That pic was taken 2 days after I got the car. Now its full of bugs and dust. Amazing how much more junk gets through the hood scoop into the I/C!
P.s - <----just felt like including a new icon.
Old 07-11-2003, 03:56 PM   #18
JDMTEG98
Member#: 38671
2004 WRX STi
World Rally Blue w/ Gold
Thanks for the pictures guys. Now heres the real question, does the strut bar really make a difference (Is it worth the money buying it?)
Where can you buy it and how much
PS: I also like the ICON >
JDMTEG98 is offline
Old 07-11-2003, 05:48 PM   #19
C-daleRidr
Member#: 18074
2008 Speed3
I'm curious as to whether or not it makes a marked difference as well. I know the old skool (GC, etc.) is pretty loose up front, but they supposedly stiffened up the new version.
C-daleRidr is offline
Old 07-11-2003, 06:26 PM   #20
euroauto
Member#: 249
05 FXT psm
12 R350
So what is the prefered strut bar? Whiteline, STI, or Cusco
Is it worth getting the Cusco V brace for the rear?
thanks jim
euroauto is offline
Old 07-11-2003, 07:31 PM   #21
STi&LT1
Member#: 36645
I put the bar on when the car had 6 miles on it...I can not really compare...I am getting ready to put on the STi rear strut bar, from what I hear the rear makes more of a difference then the front.
STi&LT1 is offline
Old 07-12-2003, 03:37 PM   #22
sube151
Member#: 3184
00 Grp N Wrx STi,
+99 V6 STi,
The subject of if the bar does anything on new age impreza's is a long discussed debate. The new age chassis shock towers are very close to the fire wall, thus extremely reducing any tower flex.
You could take this in that you do not need the extra support.
However, I would assume that under very hard driving (race course), the bar adds a little more chassis stability. Ask youself why FHI/STi would even design the bar if it wasnt needed?
It doesnt hurt.
Try http://www.avsport.com for finding bars....
NOVA: Subframe locking bolts.... those who were kind enough to offer their garages... psyber_0ptix Mid Atlantic Impreza Club -- MAIC 27 02-03-2005 02:36 PM
Will 04 STi strut bar fit GC8s? afstevie68 Brakes, Steering & Suspension 2 01-24-2005 02:05 PM
is anyone kind enough to offer me a ride in your Tein or JIC coilovers equipped WRX? VajraTLR Southern California Impreza Club Forum -- SCIC 18 04-23-2004 02:40 PM
Will a STI strut bar fit over a APS TMIC? Cashman Brakes, Steering & Suspension 3 04-24-2003 02:25 PM
Anyone kind enough to post 1.3 - 1.5" lowered WRX? malelee21 Brakes, Steering & Suspension 1 02-22-2002 01:42 AM
