Old 07-10-2003, 10:50 AM   #1
Davenow
Member#: 23676
Default Post your SM setup!!!
Here is mine
02WRX
a bunch of things removed to lighten it, nothing major, maybe 40-45lbs total removed (including replaced parts, maybe 70 or so?)
JIC FLT-A2 coilovers 7 clicks from full soft front, 4 rear 8/6k springs
22mm whiteline front Sway
22mm whiteline rear sway (adjustable, set to 22)whiteline links
P1's(heavy) 225/45/17 Azenis
-1.5 deg front camber -1.1 rear 0 toe
UTEC stage 3 (modified) map
vf24
TXS stealthback catless BPM Twister muffler
BPM up pipe
TXS TMIC (v2)
Perrin short ram
I Think thats it. I will edit if I remeber anything else
Old 07-10-2003, 11:25 AM   #2
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
Suspension Tein RA
Front Sway Stock
Rear Sway Whiteline 24mm
Wheels No comment
Tires Hoosiers, Size? No comment
Engine No comment
Tranny NO comment
I am not sure that you can legally remove 70 lbs beyond the obvious (spare, jack, Cat back.) I know mine weighs 3025 but I have probably 20 lbs of stereo in there.
AWMIII is offline   Reply With Quote
Old 07-10-2003, 11:52 AM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
DMS50 coilovers (when they work, otherwise on V8 STI-RA takeoffs)
Cusco F/R swaybar
Cusco F/R strut bar (CF rear)
Perrin Endlinks
MRT Adj rear control arms
Al front control arms
Engine mounts
Lots of negative camber and whatnot
16x8 Volk Gram Lights w/ 245/45/16 R-Compound tires
VF29 turbo
APS DR500 FMIC
Perrin short ram
TXS exhaust w/Prodrive muffler
Aquamist WI system UTEC
STI-RA 6MT w/Suretrac LSD
Autopower race rollbar/harness bar
Race seats (15lbs)
Stock steering wheel & airbags still (can save weight here)
No back seats
Battery relocated to right rear in trunk
No AC
I'm probably going to quit autocrossing in it next year and prep the car for rally so I'm looking at getting a V7/V8 2L STi motor. Otherwise I would get a 2.5L US shortblock and slap some V7 heads on there.
Why would you put no comment? Who cares...
Old 07-10-2003, 12:53 PM   #4
ConeMasher
Member#: 2135
I think he's trying to be coy. Regardless, he's running an STI-RA tranny too, and the rest of the stuff wouldn't be too hard to find out.
-- Gary
ConeMasher is offline   Reply With Quote
Old 07-10-2003, 02:51 PM   #5
spidey02wrx
Member#: 17701
not as impressive as you guys, but its a work in progress.....
JIC's 10k/10k setup depends on course & conditions
Perrin Endlinks
Engine/Tranny Mounts
GGR full turboback
PDE uppipe
ECUTek Reflash/Dyno Tune (worth every penny)
225/45/17 V700's
in my gargage waiting for my lazy butt...
autopower race roll-bar
sparco evo drivers side
I have some brake upgrades for the track, but on an auto-x course they don't really factor in. Like to get a gearset and some diffs next year. The car feels good and was actually somewhat competitive locally on steet tires, should be better on the R's.
spidey02wrx is offline   Reply With Quote
Old 07-10-2003, 09:25 PM   #6
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
I am not in SM YET but when I go I will have the following...
Have already..:
Leda Option B Coilovers set at 11 front, 16 rear.
Whiteline 20-24 swaybar set at 22
KartBoy 1st Gen Endlinks ( The good ones)
HD Sway bar mounts
JIC Front Camber Plates
Stock 19mm WRX swaybar
Whiteline Front endlinks
Energy Suspension Bushings
ProFlex Driveline Bushings
STi Motor and tranny Mounts
Perrin/Willwood Front Brakes
Stoptech Slotted WRX rotors
Stainless lines
RBF600 fluid
Performance Friction Super Pads
Motor
USDM WRX engine swap,
UTEC
Equal length Headers with integrated uppipe
TXS RFL exhaust
Ported TD04
TXS intake
Type RA gearset
Quiaffe LSD Front
ACT Clutch
Stock Flywheel (Lightened to 18 lbs)
Stock 16 in RS wheels
225/50/16 HOOSIERS
that should do it.....Hope to be competitive
Bill
Old 07-10-2003, 11:39 PM   #7
thechickencow
Member#: 16840
14 Outback
Phil,
I didn't remember to ask you today, did you actually get all that stuff installed last weekend? I should've looked at the car when I walked by it.
I was running SM this year in an index'ed street tire class, my mods aren't too major. Just running SM due to a reflashed ecu.
Jay
thechickencow is offline   Reply With Quote
Old 07-11-2003, 07:14 AM   #8
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
JIC FLT-A2
Cusco stabi bars
Cusco strut bars
Cusco front Underbrace (possibly illegal?)
Aluminum control arms
STi rear links (trailing and lateral)
Advan RC2 w/ 235/40-17 A032R (use these for everything so I don't run Hoosier)
Recaro Pole Position seats
STi Spec C steering wheel
Godspeed up and down pipe
JDM JIC 505Ti (extremely light)
Engine - nothing special, just a boost controller for now, still like the stock spool up
now for the weight - at the moment the tar is coming out so it should be under 2800 pounds
weight is the key boys
no airbags
no stereo
no A/C
gutted trunk
no rear seat
and some other stuff
need to get an tubular exhaust manifold to get those cast manifolds off the front of the car.
ellisnc is offline   Reply With Quote
Old 07-11-2003, 09:56 AM   #9
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
Gutting your trunk and removing the "tar" is not legal.
Old 07-11-2003, 10:19 AM   #10
Davenow
Member#: 23676
I dont see that anywhere in the rules.
Old 07-11-2003, 10:42 AM   #11
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
All interior pieces not specifically allowed to be removed/replaced by the rules have to be retained. So if it's not the 1) back seats, 2) front seats, 3) steering wheel then you can't remove/replace it and still be legal. Right now I run without the stuff that was in the trunk locally because no one cares, but if I went to a divisional/national event I'd put all that stuff back in. If you want to build a stripped race car then Prepared is where you'll end up.
The only thing you can do is remove something if it facilitates installing something else, and the weight removal is less than 1 pound.
Old 07-11-2003, 10:48 AM   #12
ConeMasher
Member#: 2135
If it doesn't say you can... then you can't.
Regarding "stuff in the trunk"... items that are designed to be removed (i.e. not permanently attached by a bolt or snap) may be removed from the vehicle. This generally includes spare tires, jacks, tire removal tools, and in most cars, spare tire covers.
-- Gary
Old 07-11-2003, 10:53 AM   #13
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yes I guess I should have clarified as I'm sure everyone takes out the jack/tire/etc as it's a stock class rule. I meant the liners and other assorted things that are physically attached in the trunk. Right now there is nothing but bare metal in the trunk...
Old 07-11-2003, 12:09 PM   #14
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
And how much do those liners weigh??? 2-5 lbs?
omahasubaru is offline   Reply With Quote
Old 07-11-2003, 12:22 PM   #15
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Come one, that's gotta be worth AT LEAST .0001!
(or 2 seconds on the butt dyno! )
MNbiker is offline   Reply With Quote
Old 07-11-2003, 12:28 PM   #16
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Question - are there any divisionally/nationally competitive Suby's in SM, OTHER THAN Cobb's Conebasher? There's a huge gap between Conebasher and what I've seen posted here thus far. Are there any other 350+whp beasts with a front LSD and big Hoosiers out there?
-Steve
Old 07-11-2003, 01:07 PM   #17
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
A WRX was 4th in SM at the Peru tour and I think he was 2nd behind Dennis Grant on the 1st day, which is nothing to be ashamed of. There is a pretty big gap between the guys at the very top of SM and the rest of the guys, since it's such a new class and so much can be done to the car. Bob Tunnel drives a M3 in SM now and raised the bar for everyone else. Corey Smith's S4 I think is in the neighborhood of 600-700hp now...
I'm trying to decide now whether I want to take the next step or just focus on rally instead. I have a car that I'm building for rally that I happen to autocross. It's not difficult to build a SM WRX at this point, it just takes money. I've invested alot of that, but it'd take a new engine to go to the next step. So another $5k+ at this point.
I took the liners out when I was moving the battery to the trunk and just haven't put them back yet, they are at least 1 lb! It all adds up!
Old 07-11-2003, 02:00 PM   #18
ellisnc
Member#: 4229
2003 S2000
Honestly I know that removing all the trunk lining is marginal... I know the rule about if it doesn't specifically say then you can't business. I'd say I play about as fair as others do locally in the class and I'm not going to be running nationals because I don't care to. The guys that I run against all have a lot more tire than I do and more power, they just haven't figured out the weight part yet.
Removing the tar is something I'm doing just because I'm bored with the car. The carpet will stay in per the rules (some guys try to run without interior paneling and carpet in SM I really doubt locally anyone would have a huge beef or accept that it would give me a large advantage (tar removal I mean)... I wouldn't do it if I were running nationals as there's a lot at stake. (solo2 national champion is not high on my list of things to achieve in life personally) But locally most of the guys I run with don't even have their radio or A/C removed and most don't even remove the rear seat so I'm not that concerned with it. If everyone were spending big bucks to toss weight out of their cars locally then I wouldn't feel right about it.
Old 07-11-2003, 03:16 PM   #19
Fuquad
Member#: 16164
MY02 MBP WRX. NOTHING in the trunk or back seat, no floor mats, etc...
Vishnu Stage 0 (ECUTEK Remapped ECU, Uppipe, Pulley, restrictor)
Prodrive WR Sport Springs
Whiteline 22mm Adj. Rear Sway
17" Rota Subzeros
17" Kumho Supra 712's
STi CF wing (not much help in Solo II)
Coming soon:
Intercooler Spray Kit (It's HOT out there!)
Kartboy shifter
Steel Brake Lines
Master Cylinder Brace
Fuquad is offline   Reply With Quote
Old 07-11-2003, 03:34 PM   #20
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
A wrx can be competitive in sm nationally. I cannot say that my car was too slow to compete. Cobbs car may be overkill. There are several things that they did that may or may not help. their car win autocrosses. If Mark Daddio can run in a stinking neon and trophy at nationals, a wrx can surely win with the right driver. Autocross is much more about driver skill than car prep, even at a national level. The wrx that trophied at Peru was not radically prepared. It was not even as prepared as my car is. I believe that his name on here is silverbullet. He plain out drove me and beat some VERY prepared cars on the first day. I simply am not used to the crazy speeds involved in the Peru event. Dennis Grant's car has not ever had the valve cover off. Oh and not everyone would be happy to tell you all of their secrets. There is stuff going on with autocross wrxes that almost noe of you know about and no one discusses on the internet. If you want to find out, take a walk through impound.
Old 07-11-2003, 04:02 PM   #21
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I wish I had signed up for the Peru tour because I'd really like to see how my car and my driving would stand up to good competition. We have decent competition in this area and I've certainly been beaten this year, but it would be nice none the less to see how much I'd get beaten by top level drivers. I did an event in Peru the week before with the south bend car club. It was my second event in Peru. The concrete wasn't as sticky as I remembered (I was on street tires though the last time) but the courses there are fast, there is only so much you can do on a runway. This last time I was in 3rd gear for more than just a short bit, probably hitting 65-70mph.
Old 07-11-2003, 06:33 PM   #22
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Heheheeee. Very true
-Tom
trhoppe is offline   Reply With Quote
Old 07-11-2003, 10:22 PM   #23
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
92 Mazda Miata 1.6
Piper Motorsports Cage
Fire System
Kill Switch
Window net
Gutted
Bilstien Coil-Overs
Toyo RA-1's (205/50/15)
Kosei K1 wheels (15x7)
Carbotech XP pads
SS brake and clutch lines
Kirkey Intermediate Road Race Seat....
OH! you meant Street Mod....SORRY...those are my plans for a SPEC MIATA
hehe,
Chris.
subyguy2 is offline   Reply With Quote
Old 07-12-2003, 12:37 AM   #24
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I'm going with a low grade Momo seat. The FIA certified seat will allow me now to have to use a seat brace
-Tom
Old 07-14-2003, 01:48 AM   #25
MK19
Member#: 21977
Bear s like food
Thumbs up
OK, so it's not al of what gets me into SM, but this outta tell you guys the jist of what DOES put me in SM... Man, I wish my car smoke-checked fools like dwx (I am Phil's wanna-be-biatch ):
Project Tie Fighter:
My 2002 Subaru WRX Sport Wagon upgrades/modifications
17" Gold Prodrive P7's w/ 215/45-17 Kumho ECSTA 712's (street setup)
17กจ White Rota Attack's w/ 215/45-17 Bridgestone SO3 Pole Position's (dedicated auto-x setup)
Dulalmin Light Weight lug nuts
Cusco Zero-2R coilover suspension (running 2 on the street and 5-front, 3-rear on most auto-x courses)
Perrin/Wilwood front brake kit w/ Wilwood E compound pads
Cobalt Friction GS3000 Premium front rotors
Perrin/Wilwood rear brake kit w/ H6 rotors & Wilwood Q compound pads
STi short shift kit
Cusco Version II front lower brace
Cusco rear adj. 22-24mm sway bar
STi rear trailing link arm kit
STi rear lateral link kit (6 piece full pillow ball)
STi front control arm bushings (To be installed)
Blitz SBC i-D Electronic Boost controller
Blitz FATT DC Turbo timer w/ harness
Omori 45mm boost gauge
Omori 52mm oil temperature gauge
Omori 52mm oil pressure gauge
Omori 52mm EGT gauge
Gruppe-S up-pipe
Bosal down-pipe
Stromung 3d Cat eliminator mid-pipe
Prodrive rear silencer
STi engine mounts
STi gearbox mount
Samco silicone I/C hoses
Perrin crank pulley
K&N filter
Subaru WR Blue side skirts
STi mesh fog lamp covers
STi hood scoop
STi carbon fiber side marker covers (replica)
STi front grill
Subaru JDM rear pink WRX badging
Subaru JDM rear IMPREZA badging
GC8/STi oval side markers
MOMO Air Leather shift knob
MOMO leather shift boot
STi shifter trim
Prodrive embroidered front headrests
Schroth Rallye 4 harness belts (driver and passenger)
Alpine 7894 MP3 receiver
Alpine V500 series amp
Fosgate 10" sub and band pass
Flashing side marker mod
Fog lamp mod
De-railed roof racks
Air box resonator (snorkus) mod
MOBIL 1 synthetic fluids (engine/gearbox)
Auto-X alignment (-1 front camber w/ stock camber bolts; -2.5-3 w/ Cusco camber plates for auto-x)
MK19 is offline   Reply With Quote
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 10:59 AM
Post your sticker setup.... RedScooby2004 Member's Car Gallery 105 12-01-2007 12:11 PM
Post your snowboard setup wrxlvr Off-Topic 185 03-10-2007 09:45 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 04:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 01:03 AM
