Old 07-10-2003, 02:48 PM   #1
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
Default Has anyone removed the Speed Limiter on a 93-97 Impreza 2.2/1.8?
someone contacted me for "how to"
and i've not done this... no idea...
did some searches.. no conclusive answers....
anyone? gang?
not something i'd condone...
but this is for 'track days'/events etc...
yes.. with a 2.2...
cheers
Jamie
Old 07-10-2003, 03:16 PM   #2
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
I thought that all spped limiters were programmed into the ECU. In order to remove them wouldnt you have to reprogram your ECU or get a different one? I dont know thats just what I assumed.
JewPac42 is offline   Reply With Quote
Old 07-10-2003, 03:16 PM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Jamie, buy a ProECM
Old 07-10-2003, 03:54 PM   #4
AllSubaru.com
Vendor
Member#: 19819
i am not sure guys
i've never had an interest in doing this....
but i'm just trying to LEARN...
so that i can assist another member...
as well as gain this useless trivia knowledge
thanks gang....
i'll do some more digging.
Jamie
AllSubaru.com is offline   Reply With Quote
Old 07-10-2003, 03:58 PM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Seriously, the ProECM removes the limiter but I'm unsure how. You may want to talk to Larry Ganz or IWTU electronics (makes both the Torque Chip and the ProECM).
Old 07-10-2003, 06:20 PM   #6
NimrodBoz
Member#: 18500
1999 Impreza 2.5 RS
Silverthorn...ĦEs fuerte!
not all cars have the speed limiter in the ecu. my friend has a escort zx2 hes been tuning for some time (yes i know...its lame but whatever) and he sliced in a switch for the governor directly into a white wire under the cupholders and that does it.
NimrodBoz is offline   Reply With Quote
Old 07-10-2003, 06:24 PM   #7
JewPac42
Member#: 23260
Patr ick Willis
If im not mistaken that wire is still a part of the ECU.
Old 07-10-2003, 08:17 PM   #8
quentinberg007
Member#: 7887
they put speed limiters on the ej18 and ej22? bwahahahhaa... i swear my 1.8L barely made it to 100 (and that was downhill)
~~Quentin
quentinberg007 is online now   Reply With Quote
Old 07-11-2003, 03:13 AM   #9
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
If it is a 96+ you can use the OBD-II port to reprogram it without the limiters I believe.
Old 07-11-2003, 09:05 AM   #10
bigdweeb
Member#: 31035
13 Ford Explorer
13 Mazda3 Skyactiv
Just out of curiousity, does anyone know what the limiter is actually set to on a 2.2L Impreza? Would it actually be worthwile going through the trouble to remove it since it's likely set close to where the car maxes out anyway?
bigdweeb is offline   Reply With Quote
Old 07-11-2003, 10:23 AM   #11
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Contact "wac" (Wayne Chin). He's done this on his 97 OBS, even going so far as to put in a switch.
SteveS is offline   Reply With Quote
Old 07-25-2003, 11:55 PM   #12
Trizzle
Member#: 38039
1984 VW Westfalia
with EJ25 Power
there's a speed limiter? What's the cutoff? It must not exist on the RS cuz i've had mine over 130 and approaching redline in 5th
Trizzle is offline   Reply With Quote
Old 07-26-2003, 06:19 PM   #13
C17LOAD
Member#: 25488
2005 Impreza WRX STi
"Petter Solberg Edition"
well, if its the same limiter used on the 99 EJ22, then its 110 mph indicated. And with slight mods, thats nowhere near max.
C17LOAD is offline   Reply With Quote
Old 07-28-2003, 06:50 PM   #14
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
There's no speed limiter on the RS.
Old 07-29-2003, 09:40 AM   #15
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Yes there is, 5th gear
Old 07-29-2003, 08:26 PM   #16
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
You could use the Apex'i Rev/Speed meter. You can set it up so that it intercepts the speed signal, and tells the ECU that it is still under the limiter, or something.
Anthony C
Bobalouy is offline   Reply With Quote
Old 07-31-2003, 05:49 PM   #17
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yeah I was going to say its something like
drag increases at exponential rate relative to velocity
Old 08-08-2003, 09:06 PM   #18
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
~~Quentin
LMAO I was thinking the same thing.. a speed limiter on a 1.8L
SubaruImpreza_power is offline   Reply With Quote
Old 08-09-2003, 05:46 PM   #19
linsavy
Member#: 11620
1997 GF4 -STiV3
Saab 93 TX sportcombi
Wow, I didn't know there was a speed limiter on the 2.2l. So it is around 180kph. I guess I never have achieved such an excessive velocity. I have seen around 170 at a track day but ran out of straight.
That kind of speed would require a long time to achieve.
I am curious to see the answer though.
linsavy is offline   Reply With Quote
Old 08-09-2003, 07:22 PM   #20
Tkacik
Member#: 847
'06 Titan Crew Cab
'03 Odyssey - EXL/RES
I have gone 127 in my AWD 95 L. Was I close to the cutoff?
Tkacik is online now   Reply With Quote
Old 08-10-2003, 12:41 AM   #21
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
I have no idea, I cant get past 95 on the speedo.
Old 08-10-2003, 12:44 PM   #22
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
On flat road?
The 2.5L is a little better but it will take a Loooong time just to Hit 120 on the speedo.
Old 08-11-2003, 12:44 AM   #23
Tkacik
Member#: 847
'06 Titan Crew Cab
Yes, I certainly didn't get to ~127 in a hurry
Old 08-11-2003, 12:52 AM   #24
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
I really did not think that there was a limiter. My friend has a 2001 2.2l L wagon automatic and ive seen it over 120 MPH. My 95L AWD has been to 127 and i was almost out of 5th gear before i lifted. As far as i know on my 1.8ECU its only limited by the rev limter in 5th. therefor by removing the rev limiter the speed limiter would eb removed.
Hawk296 is online now   Reply With Quote
Old 08-11-2003, 02:02 AM   #25
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Originally posted by SubaruImpreza_power
On flat road?
Actually it was downhill when I was trying... 5th gear just kills my car
6-speed drivetrain into a 93-97 impreza Homemade WRX Subaru Conversions 19 02-17-2006 11:33 PM
93-97 Impreza owners with Ver7/8 swaps Billy Subaru Conversions 6 05-23-2005 02:43 AM
Has anyone removed the warnings on the sun visors? Undepelo Interior & Exterior Modification 11 10-15-2004 05:34 PM
So has anyone noticed the rubber seal on the oil filter being crushed after removal? Big_Hitter Service & Maintenance 5 04-28-2003 06:52 PM
Has anyone removed the stock Knock sensor?? TMR Impreza Technical Forum Archive 7 05-19-2000 06:52 PM
Message Board Statistics All times are GMT -4. The time now is 08:12 PM.
