Old 07-10-2003, 04:45 PM   #1
d4d4d4d4
Member#: 38925
1990 legacy wgn
Pig blood for paint
Talking Idea for making AWD 4EAT shift smoother!
I've noticed that the 4EAT doesn't warm up very easily given that such a small engine (mine is a 1990 EJ22, I would imagine the ej18 is worse) doesn't put out enough heat to keep the AWD transmission fluid loose. In driving temperatures below 60 f the transmission has problems making smooth shifts without extra carress from my part. It can be very picky about shifting in different RPM ranges, load weight, going up or down hill. No matter what the temp is outside, if I drive around in 2nd running the engine at 3k-4k for several miles, it warms the 4EAT enough so that it shifts smoothly no matter what situation I give it.
To fix this problem without high reving, I've ordered a rectangular sheet of steel from a freind. He's going to cut and bend the sheet so that it work as a skid plate. I'm making it go from the front fender under the engine and back to just beyond the AT fluid control box. Hopefully the reduced air flow will hold in heat. This should be pretty effective in maintaining a warmer opperating temp for the AT fluid control box. I'll tell you how it works out when I get it done. Until then.... Any ideas I haven't thought of??
d4d4d4d4 is offline   Reply With Quote
Old 07-10-2003, 06:47 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
It'll also improve the areodynamics of the underbody too
Legacy777 is offline   Reply With Quote
Old 07-10-2003, 06:54 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I suggest blocking of the left most portion of the radiator. The transmission "cooler" also acts as a transmission heater, bringing the temperature of the fluid up. The radiator fans and thermostat will help to balance the temperature.
Old 07-11-2003, 12:55 AM   #4
d4d4d4d4
Member#: 38925
1990 legacy wgn
Pig blood for paint
I never thought about areodynamics underneath the automobile. I wonder how much this will effect my gas milage if the sheet is thin enough? Only one way to know for sure! The engine could be double layered and I could use ultra thin steel from the engine back. Since I go offroad often I would like to protect my oil pan. You guys know how strong the bottom of the tranny is? Would it even help at all to put extra metal over it?
Old 07-11-2003, 11:10 AM   #5
Legacy777
Member#: 4800
The big thing it helps is drag. All the protruding parts catch the air and add more drag, compare that with a flat sheet of metal, the flat sheet will will produce less drag.
Old 07-12-2003, 02:42 PM   #6
rhdude
Member#: 6637
2009 Acura MDX Sport
Get some B&M trick shift, use a 50/50 mix of that and Mobil 1 synthetic... tranny shifts smooth as butter, even when cold
rhdude is offline   Reply With Quote
Old 07-12-2003, 02:44 PM   #7
rhdude
Member#: 6637
the tranny pan can be easily dented by a nice rock or even clump of hard dirt... as for the actual tranny itself...
Isn't that strong...
I has idea for make fast4r serverz. Bett4r than banner ads for thai lady boys! Asinine Off-Topic 13 02-25-2008 04:54 PM
what can I buy to make may shifts smoother? Vampyr Transmission (AT/MT) & Driveline 14 03-07-2006 10:28 PM
How to make the 4EAT shift faster? getek20 Transmission (AT/MT) & Driveline 14 09-18-2003 11:56 PM
How to make shifting smoother? Oo DaRk StAr oO Transmission (AT/MT) & Driveline 23 03-23-2003 10:38 PM
('93-'01) Idea for making long trips more comfy... dcoty Impreza Forum 8 09-29-2001 01:14 PM
