Old 07-10-2003, 06:02 PM   #1
boxerT
Member#: 16311
2004 STi
WR Blue
Default Lightweight battery recommendations needed
This is one that I am aware of and used in the past. Are there any others in a more conventional size and similar weight of 13.5lbs?
http://www.performancedistributors.com/batteries.htm
boxerT is offline   Reply With Quote
Old 07-10-2003, 06:22 PM   #2
Mr. Grinch
Member#: 34416
2002 BMW M3
Alpine White
The M3 guys have used the Dyna Batt as well as Hawker Genesis. Some can be had for much cheaper.
Some guys made their own brackets out of wood or metal. I think there might also be adapter kits to make it easierl to bolt in the place of a regular battery.
The mounting is the tricky part. The only other thing to keep in mind is your electrical system usage and climate.
I remember one guy got himself two batteries "just in case". He managed to get the Hawker Genesis batteries at such a good price. That way he could keep a spare battery.
Main concern witht these batteries is draining them accidentally.
http://www.stealth316.com/2-dynabatt.htm
Mr. Grinch is offline   Reply With Quote
Old 07-10-2003, 06:57 PM   #3
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Battery
You might look at the Miata replacement battery. It weighs a little more at 25 lbs but is cheap at $70 and lasts a long time. Over 400 CCA.
Mike McBride
MZM is offline   Reply With Quote
Old 07-10-2003, 08:38 PM   #4
MTMS4
Member#: 5227
Take a look at the PC680 battery from Odyssey (15.4 lbs),
www.odysseybatteries.com
MTMS4 is offline   Reply With Quote
Old 07-11-2003, 01:19 AM   #5
Subosche22
Member#: 20398
03 Evolution 8
Tarmac Black
BoxerT
MTMS4 sounds like he knows his stuff. I have one of the PC680's in my car it works great, let me know if you want one and depending on where you live i can get you a new one for cheap.
Subosche22 is offline   Reply With Quote
Old 07-11-2003, 11:43 AM   #6
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
I made a list of many of the batteries that were out, and their weight and specs.
It's posted in the FFI Forum (last update was a month or two ago), and I'd link you to it if the search function was working at the moment.
It lists the Miata Battery, the Hawker and a bunch of others.
Edit: Ah, it's back up now:
http://forums.nasioc.com/forums/show...hlight=battery
See my 2/16/03 post in that thread for the list.
Coati is offline   Reply With Quote
Old 07-11-2003, 01:57 PM   #7
tdxflex
Member#: 13634
I'm using a Stinger SP800 (relabled Odyssey 925), works perfect and weighs in at 25 lbs. Not so lightweight since it sounds like you're keeping yours under the hood, but mine's in the trunk. It was the lightest battery I could find (besides this Marathon battery I saw on batterymart.com for a Miata) that still had decent CCAs and reserve time. If I kept my battery in the front I probably would have gone with the PC625 but since it's in the trunk I went with a little more power.
http://www.odysseyfactory.com/specs.htm
tdxflex is offline   Reply With Quote
Old 07-13-2003, 11:39 PM   #8
archbonr
Member#: 17666
08 Forester
I just found out about this one the other day reading Scooby Mods. Looks to be the exact same as the DynaBatt, at only half of the cost.
Portable Power Systems
Nik
archbonr is offline   Reply With Quote
WTT: lightweight battery for regular battery Lexington MWSOC Private Classifieds 7 03-18-2008 05:02 PM
Need HELP installing Odyssey lightweight battery I_wanna_STI_now Electrical & Lighting 7 02-06-2008 01:49 PM
Urgent help needed... Anyone sell braile lightweight batteries in Dallas? stevenh Texas Impreza Club Forum -- TXIC 10 08-22-2006 11:27 AM
Battery Dying...Need Explanation/Recommendations IQBlue Electrical & Lighting 10 11-28-2005 01:26 AM
