Old 07-10-2003, 07:04 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Wow, where have I been? Torque meter for any ratchet (add on)
This is pretty dang cool. Lets you use any of your tools as a torque wrench! Plus its a remote display (52 inch cable).
http://www.sears.com/sr/product/summ...id=00944598000
Old 07-11-2003, 02:25 AM   #2
TaiChih
Member#: 3467
1998 Dinan3
Bleck
That's really cool, but OUCH! way too pricey.
TaiChih is offline   Reply With Quote
Old 07-11-2003, 07:31 AM   #3
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Wow... that's hella cool... and hella expensive!
TimStevens is online now   Reply With Quote
Old 07-11-2003, 11:08 AM   #4
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
Expensive for our ghetto asses, indeed.. But not that bad if it's quality, and accurate.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 07-11-2003, 11:40 AM   #5
Austin
Member#: 7089
2016 STi
I must've been living in the dark, too... I've never seen one of those. Now I must go buy one.
Austin is offline   Reply With Quote
Old 07-11-2003, 05:11 PM   #6
tdxflex
Member#: 13634
If you guys think about it, that's not that expensive. Can't find the accuracy range but if it can read 0-250ft lbs and is still accurate up to 0.1 ft lbs, it's basically 3 torque wrenches worth of accuracy. Just have to get a couple accessories like a 1/2 to 3/8 adapter.
Rotary torque sensor is non-contacting, having no brushes to wear out
Also sounds like it will never need re-calibration, in the long run this sounds like a winner.
tdxflex is offline   Reply With Quote
Old 07-11-2003, 06:21 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Its not expensive!
First, you most likely already have a large set of tools.
Second, if you look at a quality torque wrench its going to cost you 75-125 dollars anyways. This unit can measure the ENTIRE RANGE you would ever need, the overwhelming majority of wrenchs are not accurate at all at the lowest 10% and the highest 10% they are rated at.
I already own a breaker bar and large ratchet. If I didnt already own two Torque wrench I would have ordered it already. I still probably will.
The remote display alone makes this 100x better than any torque wrench. No stupid needle (that can interfear with objects around it) and no damn clicking.
Old 07-11-2003, 06:32 PM   #8
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Eh. That's about all I can say.
I'll stick with my SK torque wrench. It'll last forever (mechanical), it can crack skulls in a pinch, and it's nice and accurate
heffergm is offline   Reply With Quote
Old 07-11-2003, 07:34 PM   #9
ShotgunTC88
Member#: 30970
$129 High priced?
Sheeeet, Check out the ol, "Snap on Truck" someday and see how much ol, Shotgun got greased for ONE dam tourqe wrench!!
Im gettin one of those today!
(Even if its just to impress the nieghbers.<GGGGGG>)
.02
Shotgun
ShotgunTC88 is offline   Reply With Quote
Old 07-11-2003, 07:57 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
heffergm: Last forrever because its mechanical? You've never broken a tool? Not a good reason against it. Ive broken ratchet/breaker/torque wrench and attachments many times.
Your mechanical unit will become less accurate as it ages. You also cannot compensate for inacuracy over a small range like an electronic unit.
Old 07-12-2003, 02:48 PM   #11
rhdude
Member#: 6637
2009 Acura MDX Sport
I'd buy one if it were'nt so expensive...
rhdude is offline   Reply With Quote
Old 07-12-2003, 04:24 PM   #12
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Actually it says +/- 3% . So, say, 100 ft/lbs would be +/- 3 ft/lbs. Doesn't sount too bad, though. I don't know what normal torque wrenches give for accuracy.
I guess none of you guys are craftsman club members? This meter has been around for a while... it was in one of the craftsman club mailers at least a few months ago. There's really no reason not to sign up, actually. It's free and you get "special" deals.
ws6fiero is offline   Reply With Quote
Old 07-12-2003, 04:39 PM   #13
tdxflex
Member#: 13634
Quick browsing on the snap-on website, the tolerances for almost all of the wrenches is guaranteed <4%. Looking at some of the craftsman ones on the sears site, tolerances are also 4%, some of them 3%, basically everythings about the same tolerance. The big pro of the electrical sensing one is that there are no gears to it so it won't need re-calibration. If I didn't have torque wrenches already I would most likely buy this.
Old 08-07-2003, 11:29 PM   #14
tdxflex
Member#: 13634
Well I was able to get one of these and first impression, it's hard to get used to. I've only used it for a few minutes so far since I don't really have anything I need to torque down but it refreshes so fast that you have to just listen and trust the audible beeps for when you reach your target torque setting. But as you get closer to your target it already starts beeping, and beeps faster as you get closer to it. I'm sure if I use it more often I'll get used to it, it has a few different modes, but right now I think I like my torque wrenches better.
Also, in the manual it says the range of the sensor is up to 150 ft-lbs, 3% accuracy from 50-150 ft-lbs, 1.5 ft-lb accuracy from 0-50 ft-lbs. And magnets and strong magnetic fields can cause damage to the sensor. The remote display has a big rubber casing to it like their multimeters, but the sensor has none.
Agent Orange! Wow where have I been? Other recs? zoomfactor Off-Topic 5 02-08-2005 01:37 PM
Where have you been... Mopho Off-Topic 15 01-02-2005 01:45 PM
Where Have You Been? WagonMonster Off-Topic 59 11-17-2004 11:35 PM
Alice In Chains... Where have you been all my life? WRXGuyInUSA Off-Topic 65 07-09-2004 06:51 PM
Hmm, where have I been? Is anything going on this weekend? delectron Bay Area Impreza Club Forum -- BAIC 0 08-20-2000 12:46 AM
