Old 07-10-2003, 07:30 PM   #1
Hojai
Member#: 2190
Default Do you guys just change the clutch disc?
After your aftermarket clutch needs to be replaced, do you guys replace the clutch disc only or replacing the whole new clutch kit?
Hojai is offline   Reply With Quote
Old 07-10-2003, 08:47 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Every time you pull the tranny to change clutch, you should always change the clutch disc, pressure plate, and throw-out bearing.
tmat3 is offline   Reply With Quote
Old 07-11-2003, 02:13 AM   #3
TaiChih
Member#: 3467
1998 Dinan3
Bleck
It really depends on how many miles the aftermarket clutch pressure plate has and what the condition of the fingers are in. It is really an issue of "do you want to risk spending money for a second install to replace a possible too worn pressure plate". IMO, once my clutch goes, I'm just going to get a replacement kevlar disc.
TaiChih is offline   Reply With Quote
Old 07-11-2003, 02:27 PM   #4
trilap5e
Member#: 19644
2005 WRX STi
do the whole thing! you won't regret it... also check the flywheel for wear and hotspots... you don't want to have to waste the time and $$$ to go in twice when you could have gone in once. it's worth the $$ up front to do it right the first time.
trilap5e is offline   Reply With Quote
Old 07-11-2003, 02:35 PM   #5
SuperRoo
Member#: 36928
Default also turn the flywheel
On any high HP application to seat the new disk right you need to turn the flywheel. It does not cost that much nor does it take alot of time. It is well worth the time and money spent to know it is done correctly.
SuperRoo is offline   Reply With Quote
Old 07-11-2003, 03:38 PM   #6
Hojai
Member#: 2190
i think i'll go w/ the ACT clutch kit w/ street disc again this time........
thanks guys................
anyone knows a good deal?
Old 07-11-2003, 05:04 PM   #7
Z1 Performance
Member#: 9327
You certainly do not have to change everything everytime you are in there...definately do inspect everything though.
ZIts pretty easy to do...look for hot spots and cracks on the flywheel, as well as signs of uneven wear on the disk. For the pressure plate, again you are looking for any fingers that seem out of whack, as well as cracking or hot spots on the friction plate.
Adam
Z1 Performance is offline   Reply With Quote
Old 07-11-2003, 09:27 PM   #8
Hojai
Member#: 2190
b/c my car is almost unable to drive so i just want to have everything i need in hand before i go to my mechanic's house
Thanks for your opinion though.......
What do you guys think about Southbend clutch? socomcaptain05 Transmission (AT/MT) & Driveline 6 09-04-2008 12:43 PM
what do you guys think about the subaru sub the sell? Shamrocked Car Audio, Video & Security 2 11-26-2006 01:22 AM
what do you guys think of this? clutch shudder fix? OneArmedScissor Texas Impreza Club Forum -- TXIC 9 04-07-2005 07:44 PM
Turbo'ing with a small set-up, do I need to change the clutch? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 13 08-02-2002 09:58 PM
What do you guys think of the about the STS & OEM Boost Gauge Need4Boost Newbies & FAQs 1 05-18-2002 01:21 PM
