Old 07-11-2003, 01:48 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Cleaning now that heads are off? And Valve adjust question?
Okay I have my heads off and they have been sent to be O-ringed. Now that the heads are off I see that there is alot of buidup on the pistons. How should I clean this up so that evertying is nice when I put it back together. I don't want a higher compression ratio due to deposits on the pistions.
I also have to adjust the valves when I put my cams and such back in (DOHC) and I woudn't mine some advice or pointers. I do have the Haynes manual to help me through it but any addition tips would be apprecited.
Joshua
yebokmj is offline   Reply With Quote
Old 07-11-2003, 03:06 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
when I took off my heads, I bought some carb cleaner, and spray it on the pistons, let is sit for a few minutes, then scrub them down with a soft wire brush to make sure you don't scratch them..
rhdude is offline   Reply With Quote
Old 07-11-2003, 03:46 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Carbon buildups are normal. I think I've understood that if you use a misting spray bottle of water and spray the intake charge as it is running, you can actually cause the carbon to burn/come off.
Old 07-12-2003, 02:31 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I use break cleaner. That stuff gets anything off.
But honestly, you don;t need to worry about it uping your compression. Just get on it real hard a couple times and it will clear a lot of that away.
Eric SS is offline   Reply With Quote
Old 07-13-2003, 05:44 AM   #5
Unsung Boxer
Member#: 37196
Both Brake and Carb cleaner will work fine for the job. I prefer brake cleaner. Go ahead and spray it down best you can and wipe it off. Should get it good. I would even put a little motor oil back into each piston, just because that brake cleaner might take alot of the initial oil off of the cylinder wall.
As far as valve lash goes, I believe that you need to use an angled feeler guage. Unfortunately if you dont have one, they cost almost as much as the adjustment does itself.
I suggest bringing the heads to any repair shop and having them adjust the valve lash there. I dont think they should charge you more than an hour (about 60 bucks) to do it, since you have the heads off, and the valve covers off.
Hope that helps
-Jake
Unsung Boxer is offline   Reply With Quote
Chicks that are hotter now. Now that they are older. Lucky Loser Off-Topic 168 10-15-2009 02:41 PM
What mods to do while heads are off?? Cams, Port and polish, Blah blah blah???? supersuby2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-23-2008 08:40 PM
EJ20 valve adjustment question Loomin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-30-2006 09:01 AM
Now that Haltec's are cheap are they worth it? Oo DaRk StAr oO Engine Management & Tuning 1 03-09-2003 12:44 PM
Okay, now that people are getting their WRX's.... subpreza Texas Impreza Club Forum -- TXIC 19 03-20-2001 06:21 AM
