Old 07-11-2003, 07:33 AM   #1
codger
Member#: 13486
06 Legacy GT wagon
Default Oil leak from starter - overfilled on oil change?
My '02 OBS has a small leak or seep around the starter. It also appears that the Quick lube place overfilled on the last oil change, and I thought maybe the extra oil is getting blown out wherever it can. (I bought a pack of filters from the dealer, and just go to the more convenient oil change place). It's a long shot, I'm hoping that changing the oil again, with a proper fill level, will fix the problem.
Most likely I'll end up at the dealership to get it fixed under warranty. Anyone else seen this problem?
Jim
codger is offline   Reply With Quote
Old 07-12-2003, 02:50 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
around the starter? could it be leaking out the intake and blowing over there? any pics?
rhdude is offline   Reply With Quote
Old 07-12-2003, 05:19 PM   #3
rilles
Member#: 14332
2001 Forester S
gold
I had an 02RS, it was way overfilled with oil one time - ever since that time the rear oil seal slowly leaked. Dealer confirmed the leak, but the car was wrecked before further investigation.
rilles is offline   Reply With Quote
Old 07-16-2003, 08:33 PM   #4
codger
Member#: 13486
06 Legacy GT wagon
That had me a bit concerned the last few days. But I took it in to get a few things looked at, and the mechanic found that the oil was coming from my Amsoil filter . I thought I had wrung and blotted the excess oil out, but the engine heat loosened up one last trickle of Amsoil air filter oil.
Jim
'06 STi- 1st oil change done and oil leaking from filter? Domo-Kun Service & Maintenance 30 10-16-2005 06:57 PM
oil leaking from the valve cover side as long as the engine on bebeGDB Engine Management & Tuning 4 07-19-2004 08:08 PM
Oil overfill on oil change- bad? Integra-R Service & Maintenance 5 09-28-2003 01:57 PM
Help please...much oil leaking from pipe on pass. side of firewall Danno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-31-2003 05:26 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 07:44 PM
