Old 07-11-2003, 11:24 AM   #1
poison
Member#: 37678
Default What is the ideal pressure for RE92?
The dealer set them at 32 psi all around at my tune up last week. It seems soft for hard driving, but will inflating more cause uneven wear?
Thanks!
poison is online now   Reply With Quote
Old 07-11-2003, 01:12 PM   #2
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
85 psi.. watch em blow and get a good set of tires Just kidding, the sidewalls of the RE92's are soft though, I used to ride around on 34/37 F/R, and then 36/39 for auto-x.. never saw uneven wear except for poor alignment from the dealer.
-- Steve
SLKWrx is offline   Reply With Quote
Old 07-11-2003, 01:46 PM   #3
allythom
Member#: 23346
02 Silver WRXwagon
07 RAV4 V6 09 Mazdaspeed3
Owners manual says 32F 29R for my WRX wagon if I remember correctly. I found this to be too soft and bumped it to 36/37F 33/34R.
I have just got new Continental Conti Extreme Contacts that I'm running at the same pressures right now (and it feels substantially firmer).
Alun
allythom is offline   Reply With Quote
Old 07-11-2003, 07:52 PM   #4
poison
Member#: 37678
Default What's this?
Here's why I posted this old noob question again. Two people reply with different opinions; same thing happens when I do a search: 20 opinions split right down the middle!
I saw a post the other day about how to dial in more or less understeer just by tweaking the front/rear tire pressure, but I do'nt remember the pressures or even which is supposed to be harder and which softer. Anyone got that link?
Thanks for repltying (you know what I mean)
Old 07-12-2003, 01:06 AM   #5
ripvw
Member#: 27790
http://forums.nasioc.com/forums/show...hreadid=203801
I run an otherwise stock wagon at 35F/30R for reasons given in this thread.
Gary
ripvw is offline   Reply With Quote
what is the Ideal Air Intake Pipe Size Jerry Xu Normally Aspirated Powertrain 2 03-09-2008 01:37 PM
GT35 users - What is the ideal up-pipe diameter? bugeyes Built Motor Discussion 8 04-18-2007 07:55 PM
What is the ideal 2.5 compression ratio ? bugeyes Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-02-2005 03:26 AM
What is the ideal EGT temp.? Leonardo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 12-22-2002 06:49 PM
What is the ideal offset for 18x7.5 wheels? scootr Brakes, Steering & Suspension 9 04-27-2001 06:26 PM
