Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 07-11-2003, 03:23 PM   #1
highspeed11
Member#: 30937
2005 Legacy GT
GRP
Default Urgent help needed
ok here's the strory: I went to change out my fuel filter so I follow the instructions on http://www.scoobymods.com/forums/sho...=6239#post6239
except I reset the ecu before I changed it because I was going to change the air filter too but it was too big so I didn't.
Well any way I reconnect the battery and go to start the car which at first it doesn't want to start I figured this was reasonable after the change. on the 3rd crank it starts up but then i watch the rpm guage just drop and then it stalls. so I start it up again and same result.
I start it again then give it a little gas and it will stay running as long as I am giving it gas then dies out when I let up. What the hell did I do wrong? Would the air filter box not being on tight (although I think it is and shouldn't matter anyway) have anything to do with it? Any suggestions? thanks
highspeed11 is offline   Reply With Quote
Old 07-11-2003, 03:40 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
OK, here we go.
1-Did you get a CEL?
2-Are ALL the plugs/lines reconnected?
3-Are all the intake parts reconnected?
I am guessing you did not get something together correctly and it is messing with the ECU.
Double check everything again.
Resetting your ECU should not have been a problem with any of it.
Old 07-11-2003, 03:53 PM   #3
highspeed11
Member#: 30937
2005 Legacy GT
GRP
1.Nope no CEL, it wouldn't even stay on that long for me to see one
2. Yeah I only undid the 2lines that go to the fuel filter and put them back with the hose coming from the "rear" to the IN tube on the filter and the hose going to the "engine" to the OUT tube on the filter
3.It should be becaude I only removed the cover and pulled out the air filter then I put it back together just the 2 clips on the side and the 3 notches on the bottom.
Old 07-11-2003, 05:38 PM   #4
phantom
Member#: 14075
I am back!
i am.... not sure..
Could the fuel filter be in backwords?
phantom is offline   Reply With Quote
Old 07-11-2003, 05:42 PM   #5
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
My guess is that you did not refill the filter with fuel, so possibly air got trapped in your lines.
I don't know if continued cranking would push the air out through the injectors (or good for the injectors), or if you would need to bleed the system at its highest point.
Not really helping, just throwing ideas out there.
-Todd
tcs007 is offline   Reply With Quote
Old 07-11-2003, 06:26 PM   #6
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Try turning the key to 'on' a few times(maybe 3 or 4), which will kick the pump on. Each time, hold it there and listen for the fuel pump(a small hum) for about 5 seconds. Then turn it off, and repeat. After a few times, try and start the car and see what happens. This will ensure you have good pressure up front BEFORE you start sucking the fuel into the engine.
Speedwagon is offline   Reply With Quote
Old 07-11-2003, 06:26 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Turn the key to the ON position and wait 45 seconds. Then try to start it.
The fuel pump will run for a while even though the car isnt running. It might not have been up to pressure yet.
Also make sure the MAF (if you have one) didnt come disconnected
Old 07-11-2003, 06:33 PM   #8
highspeed11
Member#: 30937
2005 Legacy GT
GRP
I was thinking that but I'm not sure what it is exactly and what it hooks up too I'm gonna try leaving the key in the on position thing. (cross my fingers)
Old 07-11-2003, 06:56 PM   #9
highspeed11
Member#: 30937
2005 Legacy GT
GRP
OK never mind thanks for helping out the n00b. I finally saw the THICK hose that wasn't connected from the engine to the airfilter tubing.
To think I want to go to school for this
Old 07-11-2003, 07:31 PM   #10
richeich
Member#: 1353
2001 Impreza 2.5RS
Yep, I've finally learned that lesson as well. Anytime you've been poking around under the hood, and then the car doesn't run right, check the vaccum lines/hoses. Nine times out of ten I've knocked something loose, or just forgot to reconnect it.
Rich
richeich is offline   Reply With Quote
Old 07-11-2003, 08:01 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
Speedwagon: I thought the pump ran for 60 seconds when the key is in the on second.
Old 07-11-2003, 10:49 PM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Glad you figured it out.
Also glad I had it covered in my post.
Old 07-12-2003, 11:53 AM   #13
lucien2
Member#: 1519
1998 Volvo V70R
I was on my way to post this, but it looks like you got it. I did the same thing a couple years ago.
lucien2 is offline   Reply With Quote
Urgent! help needed Urgent! iamrazor Legacy Forum 20 01-02-2006 03:43 PM
Urgent Help Needed on Truck Flood ! Im'Pat'za Interior & Exterior Modification 3 04-01-2001 10:23 PM
Urgent help needed with 91 Acura Intake. munkis General Forum Archive 12 01-01-2001 03:37 PM
Urgent Help Needed for Buying Kumhos! VALENTA New England Impreza Club Forum -- NESIC 1 06-11-2000 11:37 PM
Urgent Help Needed about Kuhmo Tires VALENTA General Forum Archive 3 06-11-2000 01:52 PM
