Old 07-11-2003, 03:46 PM   #1
squeeze
Member#: 36778
2003 WRX
Default Oil Analysis Results 7000 miles
At about 1700 I had switched out the stock fluids and put in Schaeffer's Supreme 7000 5w-30 (part number 701). http://www.schaefferoil.com/data/701.htm
My driving style
Half of the miles were freeway and the other were city. I'm way more heavy-footed than not. I don't race from every stoplight, but I'm almost always under some boost in town.
Here's the results of my OA after almost exactly 7000 miles on this drain.
The findings are broken down into 4 categories.
Wear metals: Parts per million
Copper 33 Normal
Iron 9 Normal
Chromium 0 Normal
Aluminum 5 Normal
Lead 6 Normal
Additives: PPM
Molybdenum 243 Normal
Zinc 835 Normal
Phosphorus 887 Normal
Magnesium 5 Normal
Calcium 1461 Normal
Contaminants: %
Antifreeze 0% Normal
Fuel Dilution 0% Normal
Water 0% Normal
Silicon PPM 14 Normal
Oil Properties:
Viscosity (Cst) 11.61
SAE Grade 30W
Sulfur 46 Normal
Oxidation 5 Normal
Nitration 4 Normal
Squeeze
squeeze is offline   Reply With Quote
Old 08-02-2003, 10:24 PM   #2
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Those results look great. Here's a link to my last results at 5300 miles on the oil. I'll be running somewhere around 7k miles on my current interval (about half-way there right now).
http://forums.nasioc.com/forums/show...t=oil+analysis
drees is offline   Reply With Quote
Old 08-04-2003, 10:14 AM   #3
NotFast
Member#: 10119
I had mine analyzed at 14,000 miles, with 4,000 miles on the oil, and interestingly they said my oil looked very good & that I could probably run at least 5000 miles before changing it. And I drive my car pretty hard at the track too...
NotFast is offline   Reply With Quote
Old 08-05-2003, 12:59 AM   #4
mike270
Member#: 12863
2002 2.5RS
sorry...I'm a noob but where and how much for an oil analysis. Also how long does it take them to do it for you?
mike270 is offline   Reply With Quote
Old 08-05-2003, 02:20 AM   #5
drees
Member#: 25905
2003 Silver Wagon
I use Blackstone Laboratories for my oil analysis. It runs $20 to have your oil analyzed.
Old 08-05-2003, 10:02 AM   #6
NotFast
Member#: 10119
I used Blackstone too. They say they turn the results around right away, but my oil supposedly got delayed in transit back to them (using US Mail) and it took about 3-4 weeks.
Oil Analysis Results jhuang76 Service & Maintenance 24 04-04-2010 02:44 PM
Oil analysis results @ 38k cdvma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 08-19-2004 09:43 PM
Oil Analysis Results at 5300mi drees Service & Maintenance 53 07-03-2003 03:46 PM
Interesting oil analysis results, proof that thicker isn't better? scoobybrande Service & Maintenance 1 06-12-2003 12:08 AM
