Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 07-12-2003, 12:34 AM   #1
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Default Boost Gauge Install Walkthrough?
I just purchased a boost gauge that's going to go in a pod replacing where the OEM clock is. My friend and I are going to attempt to wire up the gauge, but have never done anything like this before... can anyone offer any tips i.e. where to route the hose through the firewall, wiring up the lighting, etc.? I did a search and didn't find anything too comprehensive.
TIA
Uncle Ben is offline   Reply With Quote
Old 07-12-2003, 12:54 AM   #2
smacksube
Member#: 4067
01 2.5 rs
when i installed mine...i ran the vacuum hose through this hole in the firewall near the steering column and ran the power wire to a random fuse in the fuse box and grounded it to this metal plate up and next to the fuse box. holy run on suntence batman.....
smacksube is offline   Reply With Quote
Old 07-13-2003, 11:24 PM   #3
Uncle Ben
Member#: 28628
2003 WRX Sedan
Old 07-15-2003, 02:20 PM   #4
BurntJamb
Member#: 13538
go to www.subaruparts.com and find the OEM boost gauge part. There is link to the installation pdf which should help you out
BurntJamb is offline   Reply With Quote
Old 07-15-2003, 04:31 PM   #5
rexxer
Member#: 27624
2014 WRX
If you want the illumination to work for the gauges, make sure you connect to both the power AND the ground of the illumination circuit... the ground is the important one as it actually changes it's potential... this had me stumped for a couple weeks as I thought a ground was a ground...
rexxer is offline   Reply With Quote
boost gauge installation RidinLow Factory 2.0L Turbo Powertrain 13 08-08-2005 04:07 PM
turbo timer boost gauge install w/ factory boost gauge Blakestyle521 Factory 2.0L Turbo Powertrain 4 10-21-2004 10:19 AM
Boost gauge install question Tex-WReX Factory 2.0L Turbo Powertrain 15 06-07-2001 12:42 AM
Boost Gauge Install / Need Additional Pieces... Ethan North West Impreza Club Forum -- NWIC 6 05-30-2001 12:35 AM
Melted hose....anything to do with my boost gauge installation Damian Factory 2.0L Turbo Powertrain 5 04-28-2001 12:39 AM
