Old 07-12-2003, 04:41 AM   #1
Big Turkey
Member#: 32118
Default An extra quart of oil.. Bad?
So I decided to check my oil this morning before I started the car to warm up for the day, and it was below the L. I thought that was weird.. so i tried three more times with the same result. I had saw small oil drips a few days before in my garage, but nothing too serious. So I went to autozone and bought a quart of 10w-30 and poured it in. I checked the oil.. right below F. Perfect.
I started the car and let it warm up and drove to work. Right before I left work, four hours later, I checked the oil again.. and it's like 1cm above the F! Is that bad? I'm moving over to either Mobil 1 Synthetic or Royal Purple on Monday, but I have to work all day all weekend so I don't have time. But should I be okay running an extra quart of oil for the weekend? BTW, I'm going to the track Sunday to run a few 1/4 passes and want to make sure it won't do any damage to the engine.
Big Turkey is offline   Reply With Quote
Old 07-12-2003, 09:50 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Once the oil level gets high enough, it will foam a bit, which is bad - not sure if you are that high though - for normal driving, you are probably ok through the weekend - I wouldn't want to take it to the track without making sure it was correct, though - why risk it? Just pull the filter and drain it - should remove more than enough oil to bring you back into the proper range (I don't think you are a full quart high)
this thing ---> <--- cracks me up!
Old 07-12-2003, 02:47 PM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
I've been told by a few people that adding TOO much oil can cause a similar problem to hydrolock... not sure if its true.. but I doubt one extra quart would do that...
rhdude is offline   Reply With Quote
Old 07-14-2003, 10:20 PM   #4
GrynReaper
Member#: 39845
1999 Impreza RS
Exclamation
Having too much motor oil in your engine can also cause too much oil pressure. That can cause problems, but as a previous poster said, don't take it out and hammer it until it's corrected. A lot of places that will change you oil for you put in too much. It's something worth watching out for!
GrynReaper is offline   Reply With Quote
Old 07-14-2003, 10:34 PM   #5
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Yeah... to follow up GrynReaper's post, I have also heard this. Supposedly the excess oil pressure can blow out seals which can be rather expen$ive to replace compared to the effort that it takes to carefully drain a little oil.
ws6fiero is offline   Reply With Quote
Is 5 quarts of oil bad? Sirlight Service & Maintenance 19 12-21-2007 07:49 AM
STi Trany oil - anyone got an extra quart? vapore0n New England Impreza Club Forum -- NESIC 10 08-08-2007 08:04 AM
How Many Quarts of Oil For a '99 RS Oil Change STI 2 NV Newbies & FAQs 6 10-11-2004 01:13 PM
Running with 4 quarts of oil instead of 4.2 ok? MaciekPL87 Service & Maintenance 6 04-25-2003 11:19 PM
How many quarts of oil for an oil change? codemunky Service & Maintenance 9 07-30-2002 06:35 PM
