#1 |
Member#: 20508
Vehicle:1998 Red Wagon New Turbo Project... |
Okay, so finally, after an excessive amount of time, I'm in the final stages of my turbo project. I'm set to jet, should be installing it in very soon. Except, I have one minor, yet major problem...
I can find very very few banjos that will suit the coolant feed/return on the stock WRX turbo. I have the bolts themselves, which seem to be 12mm - however, when it comes time to find banjos I'm at a loss. I have found a few straight fittings with some ~1/4" hose barbs. I think 1/4" is a bit small for turbo coolant, plus the straight fittings are not going to work too well IMO. I have also found some fittings from Earls. But, they are straight, with an AN end, include the bolt I don't need, and are also a whopping $17 apeice. Ideally I'd like to find some 12mm banjos with at least 3/8" hose connections, an AN-6 could be okay if the fitting was a reasonable price. Even stock WRX fittings would be just fine if I could find some used. From all I can gather from my dealer and everywhere else, the turbo itself comes with the coolant fittings, and they can't be ordered separately. Or else nobody has a clue. Heck, even stock fittings from some different car would work. Legacy turbo, DSMs, etc. They are pretty similar on most of the IHI and Mitsu turbos I've seen. Just needs to be 12mm, and I can make the rest work! HELP! Otherwise I'm going to get a 12mm bolt, drill a hole through it on the lathe, seal it, and make a nice little barbed fitting. Come to think of it, thats not a bad idea. -Brad Weingartner
#2 |
Member#: 12469
Vehicle:2000 2.5 RS BRP |
This should be of use:
Oil Outlet Pipe: 15197AA060 Outlet Pipe Gasket: 15196AA060 Bolts(2 needed): 14443AA000 Coolant Pipes (in and out in 1 unit): 14430AA121 Coolant Pipe Banjo Bolts(2 needed): 15194AA100 Washers(4 needed): 803912040 That's basically all the fittings for the TD04 except the oil inlet. Can all be purchased at subaruparts.com Last edited by Lo0mis; 07-13-2003 at 01:49 PM. |
#3 |
Member#: 37196
Oh thank god for those part numbers.. ive been needing those! I was just about to post the same question.
Brad, Email me... I havent heard from you about the Project... !!! You are impossible to find on aim anymore -Jake UnsungBoxer@hotmail.com |
#4 | |
Member#: 20508
Jake: Don't worry man, I'm hard to get ahold of cause I spend all my free-time in the garage I'll drop you a line one of these days to update you on all the nitty gritty.-Brad Weingartner |
#5 | |
Member#: 12469
#6 | |
Member#: 37196
#7 |
Moderator Member#: 922
Vehicle:04 FXT Red |
Keep in mind that feed pressures get up to 100-110psi during cold starts with thick fluid... a hose barb connection would need to be very good/strong to take that.
#8 |
Brain Stew
Moderator Member#: 4562
NWIC
Vehicle:1998 Forester,lifted 1975 VW Westfalia tin top |
I have had no problems thus far.
Knocks on all wood within arms reach |
#9 | |
Member#: 20508
I did end up making my water fittings however, they work exceptionally good. No leaks whatsoever. Score for me. -Brad |
#10 |
Heh, no... in the oil system. No idea what the coolant system pressure typically is, but I bet it's less then 30psi considering the size and type of the hoses it has to travel through.
| Thread Tools | |
| Display Modes | |
| TD04 Coolant Tubing/Banjo Bolts $10 shipped>>>> | RobBeck | Engine/Power/Exhaust | 33 | 02-26-2013 09:04 AM |
| Turbo Coolant Banjo Bolt Free Mod | WhiteRocket | Water/Methanol Injection, Nitrous & Intercooler Cooling | 2 | 01-12-2010 05:15 PM |
| WTB: td04 coolant lead hard lines and banjo | 2.5 SUBY | Private 'Wanted' Classifieds | 0 | 10-02-2008 12:42 PM |
| Coolant Banjo bolts identical? TD04 & VF22 | shoooter_j | Factory 2.0L Turbo Powertrain | 9 | 11-22-2005 09:10 PM |
| Need Torque Specs For Banjo Fitting on hard oil line on turbo | 2.2gotboost | Factory 2.0L Turbo Powertrain | 2 | 02-06-2003 06:30 PM |
