Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-12-2003, 11:22 AM   #1
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Default What 3 gauges would you get??
It seems everyone has there own ideas for what extra gauges are important to put in your STi. So the question is if you had a 3 meter pod, what would you fill it with?
And would your choice change if you also planned on getting an Apexi S-AFC II? What other gauges would you get then?
offset
offset is offline
Old 07-12-2003, 11:41 AM   #2
Seraph
Member#: 12251
I'd stick boost, oil temp and egt in mine
Seraph is offline
Old 07-12-2003, 12:44 PM   #3
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I also have Boost, EGT & Oil Pressure... but if I were to do it again, I might go with Oil Temp instead.
We already have an Oil Pressure idiot light, and it would be nice to know a bit more about the temperatures inside the engine.
On a track day, I noticed oil pressures dropping from a normal of about 75psi to about 55psi at high RPM. I figured this was a side effect of higher temps. It would have been nice to have an oil temp gauge to get the real info.
Russ
rlavalle is offline
Old 07-12-2003, 05:39 PM   #4
G-shock
Member#: 36545
- warp field strength
- matter-anti-matter conversion efficiency
- trunk-monkey rectal temperature
G-shock is offline
Old 07-12-2003, 08:27 PM   #5
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Does the rectal gauge come in Celsius??? If so could we get a vendor to start up a GB; I would be so interested in one of those!!
offset is offline
Old 07-12-2003, 10:33 PM   #6
ldivinag
Member#: 13533
04 sti
black???
i would like a single dash mounted device that has read-outs for multiple inputs. then i would press a button to cycle through everything.
if there is a warning light coming on, the device would default and stay on that input.
for example, if the oil temp gauge was at it's warning range, it would stay on it, no matter what button you press. you would override only by hitting the button for a longer duration or sequence.
ldivinag is offline
Old 07-13-2003, 08:00 PM   #7
Eltharion
Member#: 39456
2004 WRX STi
Blue / Gold
I'm planning on the best of both worlds...
EGT, Oil Pressure, Oil Temp.
(Also a Defi Boost VSD, (displays on windshield))
So, I have everything covered.... but, it's going to set me back about $1K =(
Eltharion is offline
Old 07-14-2003, 03:31 PM   #8
prost893
Member#: 29710
2004 WRX STi
WRB / Gold
I had planned on getting the Defi BF gauges in the dash pod. I wanted boost, Oil temp and Oil pressure. On a race car I have seen EGT used effectively but how much does it help on a road car? I was under the impression it was used to set mixture ratios.
Thanks
prost893 is offline
What 3 guns would you buy if you had $1k-1.5k budget?=? skimmilk68 Off-Topic 93 03-16-2010 10:55 AM
Bush supporters: what 3 mistakes would you say Bush made as Prez. mr_disco Political Playground 44 10-13-2004 10:50 PM
What 3 gauges woud you get? gpxl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-06-2001 01:52 AM
What aftermarket gauges would you install? Ginseng WRX Forum Archive 16 02-06-2001 12:28 AM
