Old 07-12-2003, 03:04 PM   #1
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
Default Link help....
Ok, i got the car started, everything is good at idle. Noticed a couple things:
a. Stutter when gas pedal is abruptly stepped on from a stand point
b. The Link is pulling something like 46 degrees of timing @ ~3-4000rpm.
The engine is a stock 2001, stock cams, and the map i have is for the COBB cams. You guys think i need another MAP or would this one work good? I need to do some tuning and datalogging. Well, thanks for your help in advance.
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 07-12-2003, 04:22 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Some LINK MAPS here for DL
also, you might want to post here since skywalker is almost like 'the god' of LINK tuning.
Wedge is offline   Reply With Quote
Old 07-13-2003, 10:08 AM   #3
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
Anyone else?
~Anthony.
Old 07-13-2003, 01:37 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
If its pulling that much timing, it means it thinks you knocked repeatedly in that rpm range.
-B
Midwayman is offline   Reply With Quote
Old 07-13-2003, 06:52 PM   #5
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
that link only works if you are a registered member, Wedge...
ForesterPerformance is offline   Reply With Quote
Old 07-14-2003, 09:55 AM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
What setup do you have? Link+? T3/T04? TD04? Bigger injectors, FPR and pump? etc...
Have you switched the a/f sensors? What is the a/f ratio being reported?
I have forgotten the terminology for the Link, but play with the "tip-in" settings. There's a setting for when you step on the throttle, how much fuel to add in. If it turns out that you are adding too much fuel here, then check your plugs to see if they are fouled.
And yes, it sounds like you are knocking, and badly. Can you post a datalog? Use the stock timing settings that comes with the hard-coded Link map. Again, check the a/f ratio and adjust accordingly.
wcbjr is offline   Reply With Quote
Old 07-14-2003, 10:37 PM   #7
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
Link+, stock 2.5 internals, 2.5" full exhaust, SX FPR set to 40psi, 440cc RCs, Ludespeed III kit.
The knocking, i can hear. It doesn't happen after 2500 - 3000 rpms. I take the car datalogging but not for long. I try to tune but nothing happens. I might switch the COBB cams in the heads over the weekend. As of now, Bill at I-speed will email tune the car. But the one thing I am afraid of is, since the engine was from a rollover car, the timing might be off. I have to check and make sure everything points to the sky...
~Anthony.
Old 07-14-2003, 11:01 PM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I can offer up a map of mine. I had the same setup as you.
http://67.67.169.97/linkmaps/good_one.pcl
Try that, that was mine that I used for a few months and the one Graham started with.
Old 07-15-2003, 03:27 PM   #9
Delicious Tuning
Member#: 1990
Looking at the MAP currently...
Delicious Tuning is offline   Reply With Quote
Old 07-15-2003, 09:41 PM   #10
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
wcbjr - That map looks like it's good. I didn't hear the car knock or anything. I am still datalogging tonight and see the results. I also changed O2 sensor, and spark plug wires. Also cleaned the residue off of the coil pack for cyl #2, it was black and blue.
Thanks for your help everyone!
~Anthony.
Old 07-16-2003, 05:46 AM   #11
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
few quesions
-can i use these maps?
-which ones do i use? what is the worst that can happen if i use one of these maps
-how do i know which LINK i have :\
scoobyimpreza is offline   Reply With Quote
Old 07-16-2003, 11:18 AM   #12
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
You've got an L? Unless you did a 2.5 transplant, I would not use my MAP.
Cusco rear adjustable arms/links help wlelandj Brakes, Steering & Suspension 4 04-07-2003 10:13 AM
Link help Skulltoy Engine Management & Tuning 0 03-30-2003 11:40 PM
link help mkbvictory Engine Management & Tuning 5 01-15-2003 02:46 PM
link help!!!!! gabewrx Engine Management & Tuning 9 10-22-2002 02:49 PM
Link help Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 51 05-22-2002 03:18 AM
