Old 07-12-2003, 05:27 PM   #1
element533
Member#: 37575
2012 WRX Std 4D
Unhappy Oil filter leak or just spillage?
Hey guys,
I'm kinda worried. I just did my 4th or 5th oil change, and I'm getting a little drop of oil on the bottom of my filter now. I wiped it off and then it came back.
When I installed it, I took special care to wipe down the mating surface, lube the gasket, and prime the filter beforehand. I've tightened it as tight as I can by hand (which has been sufficient in past oil changes).
Could it be that this is just excess oil draining from the outside lip of the filter from when I primed it? I was kind of messy when I did that and I just dumped a bunch of oil all over the filter. There was still some oil pooled around outside the rubber gasket when I installed it.
I guess that's probably what it is, but I just want to make sure it's not a defective gasket or something serious like that. Has this ever happened to anybody else?
As always, thanks for the feedback!
Steven
element533 is offline   Reply With Quote
Old 07-12-2003, 10:07 PM   #2
tdxflex
Member#: 13634
what you're describing definately sounds like it. If it were a leak at the o-ring I would expect more oil to accumulate and drip down to the floor. On my second most recent oil change it would take a few days to appear on the filter but never enough to drop.
tdxflex is offline   Reply With Quote
Old 07-13-2003, 12:31 AM   #3
element533
Member#: 37575
2012 WRX Std 4D
Yeah, I think that was it. I wiped it off twice and it hasn't come back yet.
Thanks for your input!
god i love that banana...
oil filter leaking, subaru changed my oil WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 10-18-2006 06:51 PM
New Oil Filter leaks? Ringboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-11-2005 09:58 AM
Oil filter leak? sti_rx7 Service & Maintenance 12 03-26-2005 10:37 PM
Ever had your oil filter leak? DANACoOp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-26-2004 01:42 PM
oil filter leak crazy_sherm Service & Maintenance 2 02-08-2004 07:01 AM
