Old 07-12-2003, 06:22 PM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default 2.5rs front end converison parts list
I just though it'd be helpful for people who want to do the front end converison and what they need
if u have a 97 + impreza you'll need
2.5RS hood with scoop and vents
2.5RS front bumper cover with fog lamps and brackets for the fog lamps
((you might need the 2.5RS bumper bar))
if u have a 97 - impreza you'll need
same as 97+ but you'll also need
97+ headlights
97+ grill
you will need a 2.5RS front bumperbar
u could get an aftermarket grill for the 97+
for headlights u could get 99+ since 99-98 have a defused headlight or go with some morrettes
is there anything I'm missing?
questions comments?
i kno when I first got my subaru I wanted to know what I needed for a converison so I though it'd be helpful
scobaru is offline   Reply With Quote
Old 07-13-2003, 10:48 PM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
With my experiance, I would highly suggest getting the updated bumper beam to go with the updated skin. It's only 4 bolts that need to be removed, so it is easier than tearing your current bumper beam to shreds.
[shameless plug]
And the kartboy fog lamp brackets make mounting Hella 500 fog/driving lights a breeze. The wiring was the only PITA that I had. Not finding the right wires, but snaking the wires through holes and other places to get them down to the lights.
Buying the pre-wired harnesses is also a huge recommendation.
Feel free to ask me questions, I'll do my best to answer them.
AJ
AJ711 is offline   Reply With Quote
Old 07-13-2003, 11:05 PM   #3
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
Kinda related, is the 98 L model bumper beam the same as the RS bumper beam? I'm getting a new bumper for my car, and want to know if I'll have to hack up the stock bumper beam.
fellfrosch7 is offline   Reply With Quote
Old 07-14-2003, 12:16 PM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
no they are diffent you can hack tho
ok so how about this for a ver 5 (my99-01 RS)bumper
<=96
head lights
turn signals
grill
bumper cover
bumper beam
fog lights
fog light brackets
wireing, relay and switch
>96
hood w/ scoop and vents
turn signals
bumper beam
bumper cover
foglights
fog light brackets
Old 07-14-2003, 12:41 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Good idea for a thread.
You do not have to do all of this in one big swoop.
You can use your pre-MY97 headlights with the MY97+ hood. You will have to remove your old grill though. You cannot use the MY97+ headlights with the pre-MY97 hood however. The MY97+ grill can be used with a MY97+ hood and the pre-MY97 headlights. There will just be a gap in the upper, inner corner between the grill, headlights, and hood.
The bumper skin update can be done seperately from the hood/headlights. Foglights and brackets are not needed. You can just opt to install the foglight covers and save yourself the headache. I do believe you need a MY99-01 RS ( or STi lightweight) bumper beam to update the front bumper skin. Rear bumper and beam is the same between the Ls and the RSs for the most part.
-Jon
Old 07-14-2003, 03:05 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
whats the difference between the hella fog lamp's and the stockies? my guess is there brighter sooo what do they look like? and were do I get em?
oh yah another thing about the converison i've noticed that 97+ mirrors are powered were as pre 97 cars dont have power mirrors the motor in the mirrors bluge out the rear view mirror cover witch looks better than the flat ones.
Old 07-15-2003, 05:55 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I'm not quite sure where you are referring to. I haven't looked very closely, but a local MY01 Outback Sport looks almost identical in regards to the mirrors except that they are body matched whereas mine are just black plastic.
-Jon
Old 07-15-2003, 09:03 PM   #8
EddyRS
Member#: 1257
2000 GC8 WRX
93 RS-W Wagon (White) RIP
NOPE......
I have a 93 L Wagon and it has powered mirrors. They are just black, and a little more square then my 00 RS units.
I have done the front end conversion but to a 97 OBS front end. On the RS the front beam has an extra piece welded below the main beam that wraps around the radiator inlet opening, where as the L and OBS is the same and only is the main beam. I do plan to later get a 99-01 RS front bumper, or may opt for a replica 22b front skin, but wanted to get rid the of the old 93 bumper ASAP, so opted for a 2000 OBS unit (The price was right )
The rest of the car is being swapped as well. (Engine/Tranny/Interior/Suspension/Wheels/Tank/wiring......heck, let me just say everything and be done with it).
Cheers
EddyL.
EddyRS is offline   Reply With Quote
Old 07-15-2003, 10:58 PM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
well if you guys wanna know what I was talkin about then someone Host my pictures!! pleaseeee and I can show u the diff
E mail me at S15skyline@aol.com
Old 07-15-2003, 11:42 PM   #10
British Banger
Member#: 34491
Here is a question;
How do you remove the bumper off of an RS?
British Banger is offline   Reply With Quote
Old 07-16-2003, 11:02 AM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Four bolts where the bumper beam attaches to the frame and some clips. You can read about it here.
-Jon
Old 07-16-2003, 12:49 PM   #12
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Rallylights.com will have your answers as to where to get them. They are a great shop, and I have had many pleasant dealings with them.
As for comparison next to stock lights, I'm not sure. The Hella 500's are 55W bulbs (with the HD wiring setup, you could easily put 85W or 100W H3 bulbs in there, oooohhh). The only thing that I can think of is that the fog lights fluted pattern really throws an awesome amount of light right infront of the car. And it casts it off onto the side of the road as well. I've never tried the driving lights, but it'd be a simple swap of the lenses (they're just kinda expensive, so buy the acrylic covers as well, a very worthwhile investment).
I'll see if I can scan in or take some pictures of the lights on and stuff in the coming nights.
AJ
Old 07-17-2003, 02:02 PM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Here you can see the different types of mirrors. Oldest mirrors are in the left and newest mirrors are on the right. You can see the progression from square shaped to rounded.
-Jon
Old 07-19-2003, 09:51 AM   #14
EddyRS
Member#: 1257
2000 GC8 WRX
Jon,
I have those black "Square" Mirrors on my 93....and they are powered. I'll try and post a photo. I think that as far as the mirrors are concerned, it is only cosmetic, and can be both Manual and Powered in all styles. It all comes down to what package came on the car new.
Ed
Old 07-21-2003, 10:31 AM   #15
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Fixed it. I took a guess on that one and looks like I was wrong
-Jon
Old 07-21-2003, 09:37 PM   #16
EddyRS
Member#: 1257
2000 GC8 WRX
Tis OK, We're all human......most of us at least
EddyL.
Old 07-22-2003, 06:15 PM   #17
stentorian
Member#: 12959
2008 Scion xB
Quick question then. I have a 93 L and want to know if the version 1-4 style bumper skin will fit, or do I have to buy lightweight beam no matter what? This q stumped one of the guys at RalliSpec, heh!
-Joe
Oh yeah if you have a 93-96, you don't have to update headlights, RS hood will hang ovr a bit, but looks fine. As for the grill I can't remember if the guy replaced the grill or had nothing there. Someone on here did it, has pics.
stentorian is offline   Reply With Quote
Old 07-24-2003, 03:13 PM   #18
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I'm pretty sure that my RS hood would NOT close with my MY96 grill. The grill is currently off my car. The RS hood fit just fine over the headlights though. There will just be a gap in the inner top corners of the headlights and, as of yet, I have been unable to find a grill that would work with the old headlights and the new hood.
I do have an update as to grill compatabilities though. The updated grill will NOT bolt in with the older style headlights. The older headlights are slightly wider than the new ones so the grill does fit between them and the lower mounting tabs are in slightly different locations.
If I were a guessing person, and I usually am, I would think that the Ver I-IV would fit your bumper beam. The RS uses a Ver V/Vi bumper skin it would definitely be needed for it. Contact suberboy, as he has a Ver IV on his MY93.
-Jon
Old 08-03-2003, 03:54 PM   #19
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I recently reinstalled my MY96 grill onto my car. The car has a 2001 Outback Sport hood, MY96 headlights, and MY96 grill. Everything went together just fine. There is a small gap between the grill and the hood because the updated grill is slighly taller.
My original assumption that this would not work was because my hood latch (mounted on the hood) was bent and preventing the hood from shutting properly.
-Jon
Old 03-16-2004, 05:16 PM   #20
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default this post is old
I though I'd like to up date this. did my RS front end converison a year ago around the time I made this post and I still dont have a grill ahhaha
pictures of before and after
I'm sure you've all seen my car and sick of lookin at it
but I got the 97+ mirrors as u can see instead of the old school Flat style
Old 01-05-2005, 08:01 PM   #21
prmedina1986
Member#: 78784
Default question about front end replacement
I, own a 96 ImprezaL2.2 and have some front end damage i would like to replace with 99-01 fenders, bumper and later the hood and lights,please helpwould i be able to replace without modifications. Thank you for your help
prmedina1986 is offline   Reply With Quote
Old 01-05-2005, 08:11 PM   #22
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
yep if you read the whole thread you'd know you can do that lol. the difference between the 97-01 fenders compared to your 96 fenders is 97+ has no molding on the fender pre 96 cars don't have these moldings. as far as everything else I listed what you needed silly!
Old 01-05-2005, 08:40 PM   #23
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Old 02-09-2006, 01:46 PM   #24
Subaruski
Member#: 39905
I am converting from a 98RS bumper to a 99-01 bumper. So i have the 99-01 housings but what do i do for a the bulbs? If you look at the pictures. I need the whole assembly that connects to the 99-01 housing. I called subaru and they dont sell just the wiring. What to do? Is there some universal thing i should buy? I checked autozone and they had nothing that would work. Can anyone provide a picture of the wiring i need or a part #?
98 housing
99-01 housing
I need to have turn signals before i can install the new bumper. Please help
Subaruski is offline   Reply With Quote
Old 02-09-2006, 02:12 PM   #25
Subaruski
Member#: 39905
Found it on subarugenuineparts.com
The dealer wanted to sell me the whole assmebly including the lights. buttheads
2.5rs front end cover wazzupidaug5 Exterior/Styling 1 05-06-2009 09:07 PM
WTB: 2001 2.5RS front end parts JDM22bSTi Private 'Wanted' Classifieds 3 01-29-2009 09:47 PM
WTB: Front End Suspension Parts 2000 Impreza 2.5RS nmack Private 'Wanted' Classifieds 0 11-09-2006 07:56 PM
Looking for a 2.5RS Front end DDMan Bay Area Impreza Club Forum -- BAIC 0 05-25-2004 12:07 PM
FWD to AWD converison parts list scobaru Subaru Conversions 24 09-30-2003 02:21 AM
Message Board Statistics All times are GMT -4. The time now is 03:16 AM.
