Old 07-12-2003, 07:09 PM   #1
QA Guy
Member#: 6739
Default What's that thing inside the oil filter?
For some reason, I was looking at and inside some of the Purolator oil filters that people here have mentioned as being compatible with the 2002 WRX and I noticed a difference.
The x14460 (which I have been using) and x14459 have something attached to the inside top of them with a U bracket.
. __
_| |_ <- looks like this (ignore the dot)
Others, like the x24458 and x24457, which look compatible, only taller, do not have this thing.
So... what is it?
Thanks!
QA Guy is offline   Reply With Quote
Old 07-12-2003, 08:40 PM   #2
CharT
Member#: 36117
2003 WRX Wagon
Are you talking about the orange rubber flap that's blocking the holes? If so, then that's the anti-drain back valve. It's for engines that have the oil filter mounted sideways. This prevents all the oil from draining to the bottom of the engine. It's supposed to keep some oil in the oil passages so you get oil pressure quicker when you start the engine.
CharT is offline   Reply With Quote
Old 07-12-2003, 08:45 PM   #3
QA Guy
Member#: 6739
No, I don't believe so.
This thing is held on by a metal bracket and is present on filters, like the L14460, that don't have an anti-drainback valve.
Old 07-12-2003, 10:04 PM   #4
CharT
Member#: 36117
2003 WRX Wagon
Then that's probably the bypass valve. It looks like a spring-loaded metal flap, right? Filters are supposed to have a bypass valve so if the filter is too dirty and clogged, oil can bypass the filter media and flow to the engine. Dirty oil still lubricates better than no oil at all.
Old 07-12-2003, 11:43 PM   #5
QA Guy
Member#: 6739
Yes, upon further inspection, it appears to be spring-loaded. I think that you're right.
Thanks!
Computer issue: It's doing that thing, with the thing again. Hazdaz Off-Topic 1 01-29-2006 09:45 AM
What's that thing... with the guy... gongzero Off-Topic 8 07-21-2004 04:35 PM
Is the ATF filter and the oil filter the same size? Kwyjibo Service & Maintenance 6 12-06-2002 10:40 AM
What size is that engine plug near the oil filter? Eric SS Normally Aspirated Powertrain 14 11-12-2001 05:22 PM
Message Board Statistics All times are GMT -4. The time now is 09:18 PM.
