Old 07-12-2003, 08:48 PM   #1
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
Default rear camber bolts = front camber bolts?
what's the difference between rear and front camber bolts? if i bought 4 rear bolts, would that be good enough for the whole car, or would i need to get front-specific camber bolts?
Penguinking is offline   Reply With Quote
Old 07-12-2003, 10:01 PM   #2
CharT
Member#: 36117
2003 WRX Wagon
The front camber bolts are larger diameter. The WRX comes with front camber bolts, but the range of adjustment is less than aftermarket bolts. I was able to get -1.4 degrees of front camber with the stock bolts. I'm guessing aftermarket rear bolts would work for the front, but the stock front camber bolts won't work at the rear.
CharT is offline   Reply With Quote
Front camber - smaller front adjustment bolt chimchimm5 Brakes, Steering & Suspension 3 08-27-2008 02:53 AM
Tokico D-spec, Espelir GT, RCE front camber plates, rear camber bolts Scooby921 MWSOC Private Classifieds 4 04-26-2006 07:45 AM
OEM front camber bolts, can they be used in rear? edubb11 Brakes, Steering & Suspension 7 03-10-2004 02:29 AM
Anyone try WRX stock front camber bolts in the rear? Cosworth Brakes, Steering & Suspension 2 10-02-2002 06:17 PM
oem front camber bolts fit on rear? RidinLow Brakes, Steering & Suspension 6 10-25-2001 06:23 PM
