Old 07-12-2003, 09:18 PM   #1
boom2085
Member#: 34813
2000 BMW 528IT5speed
RED
Default Newbie need clutch install help please
I have a 93 Legacy BF and I am trying to replace the clutch. I have every bolt off that I can find and I cant get the tranny and the engine to separate on the bottom I have tried using a ratchet strap to pull them apart but it does not work .I have read http://wac.addr.com/auto/obs/clutch/clutch.html and it is not coming apart so if any one that knows what my problem could be please help me.
thanks Eli
boom2085 is offline   Reply With Quote
Old 07-13-2003, 05:12 AM   #2
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Cool
I know it sounds stupid, but look for bolts that you may've missed. Also, there are locating studs that'll kind of hold the engine and tranny together until you get things at the correct angle to slide the two apart. If you're just dropping the tranny, use a jack under the engine to take the weight off the studs. If you're pulling the motor, try moving it around/side-to-side to slowly get it apart. And if you don't have it already, pick up the Haynes Manual.
Good luck!
-Milan
US2JDM is offline   Reply With Quote
Old 07-13-2003, 02:25 PM   #3
boom2085
Member#: 34813
RED
I got it out
thanks Eli
Old 07-13-2003, 03:44 PM   #4
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Originally posted by boom2085
I got it out
thanks Eli
Cool.
STi clutch install problem, please help!!! Boostises Transmission (AT/MT) & Driveline 0 03-20-2007 02:08 PM
Clutch Install Help Needed wrxxer Transmission (AT/MT) & Driveline 3 03-10-2004 06:22 PM
Help Needed. Clutch Install GQ Mid Atlantic Impreza Club -- MAIC 10 03-18-2003 03:11 PM
Newbie Needs Springs Installed WillysPU Bay Area Impreza Club Forum -- BAIC 13 12-07-2002 06:55 PM
Help I need Clutch Install Directions! MattC Transmission (AT/MT) & Driveline 1 03-03-2002 04:39 PM
