Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2014
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-12-2003, 11:43 PM   #1
DJDaizzy
Member#: 12969
Default Not suppose to put the car in reverse when DCCD in manual?
I tried to back up the car today while DCCD is in manual, the car didn't want to move, and it make a clunk noise, when I put it back to auto, everything worked fine. Am I not suppose to leave DCCD in manual during reverse? Couldn't find anything about it in the manual, thanks.
DJDaizzy is offline
Old 07-12-2003, 11:56 PM   #2
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
What setting is it in?
Zoso is offline
Old 07-12-2003, 11:57 PM   #3
DJDaizzy
Member#: 12969
First block below lock.
DJDaizzy is offline
Old 07-13-2003, 12:08 AM   #4
Zoso
Member#: 37962
2006 CGM STI
I think it's normal, but still if you're reversing and parking or tight turns I would put the DCCD to auto or open.
Zoso is offline
Old 07-13-2003, 01:12 AM   #5
DJDaizzy
Member#: 12969
Did it happen to u too?
DJDaizzy is offline
Old 07-13-2003, 05:51 AM   #6
strangerq
Member#: 13095
strangerq is offline
Old 07-13-2003, 09:38 AM   #7
Zoso
Member#: 37962
2006 CGM STI
I did hear this noise going foward at full lock, but I haven't reversed on pavement in full lock,(or close to it). I've reversed on gravel near full lock and didn't have that problem but on pavement it's different. I think it's just the normal sound of the diff binding. Why did you have the car in that setting instead of Auto?
Zoso is offline
Old 07-13-2003, 12:25 PM   #8
DJDaizzy
Member#: 12969
I was autocrossing, and forgot to put it back to auto after my run.
DJDaizzy is offline
Old 07-13-2003, 02:59 PM   #9
Tb311
Member#: 26219
From what I remember your supposed to leave it either on auto or all the way down to open when your in reverse.
Tb311 is offline
Old 07-13-2003, 11:02 PM   #10
DJDaizzy
Member#: 12969
Cool, just want to make sure.
DJDaizzy is offline
Old 07-13-2003, 11:19 PM   #11
Zoso
Member#: 37962
2006 CGM STI
Did that setting work good for you at the AutoX? How did it compare to Auto and diff open or the settings in-between?
Zoso is offline
Old 07-14-2003, 02:00 AM   #12
DJDaizzy
Member#: 12969
I only tried auto and the setting right below lock, I had a better time with it in manual, but it could have been just me getting more familiar with the course. It'll take more time to learn this car, but so far it's awesome. First time autoxing the STi and won first place in D Stock. SCCA does not have the STi in their class book yet, so I got put into D Stock. But my time was up their with the Z06 Vettes.
DJDaizzy is offline
Old 07-14-2003, 06:19 AM   #13
RS_4U2NV
Member#: 24269
2006 LGT
GRP
Check out the new issue of Sport Car Mag. they put it in AS.
RS_4U2NV is offline
Old 07-14-2003, 10:26 AM   #14
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I always keep the knob towards the rear just in case I bump the switch. In full lock or one below full lock you'll have trouble moving the car off rest on dry pavement, particularly if you have the front wheel turned. So don't do it.
ANZAC_1915 is offline
Old 07-14-2003, 10:27 AM   #15
DJDaizzy
Member#: 12969
Cool, thanks for the info.
DJDaizzy is offline
Old 07-14-2003, 04:36 PM   #16
WRXIN
Member#: 15405
2004 STI
Silver/Gold - Team Blew
A little off topic, but lucky you for being put in D Stock... there's nothing in D Stock that will compete with an STi. Sounds like your times were pretty good anyway, so congrats on running comparable to the vettes!
Out here in SoCal, a team member of ours with an STi was put in A Stock, running against Z06s. He did ok actually, considering it was he first autocross. I still haven't been to an event with an Evo against an STi. That's what I want to see. (assuming similar drivers)
-Mark
WRXIN is offline
Is it bad to drive with DCCD in manual all the way back daily? elitescouter Newbies & FAQs 6 03-27-2008 04:44 PM
big thud when DCCD is in "lock" Uncle Buck Transmission (AT/MT) & Driveline 7 02-07-2008 05:08 PM
Something wrong when DCCD is in Locked elitescouter Newbies & FAQs 14 11-27-2007 02:23 AM
What did I break? Big bang when DCCD in lock. Teh Legacy Transmission (AT/MT) & Driveline 9 09-22-2007 04:14 AM
DCCD in Auto mode. When I peel out in wet leaves, makes clunking noise. LESLIEx317537 Transmission (AT/MT) & Driveline 63 11-11-2003 11:35 PM
