Old 07-13-2003, 02:52 AM   #1
87fiveO
Member#: 39774
Question 96 2.2L TPS setting
Howdy y'all,
I'm a Ford mechanic, girlfriend has a 2.2 Impreza, I don't know much about them. OBDII tells me the TPS is bad. Can anyone tell me how to test this on this vehicle,what the voltages should be? found a good description online for the 91-94 Impreza's, is it the same?
Thanks,
Derek
87fiveO is offline   Reply With Quote
Old 07-15-2003, 01:44 PM   #2
Austin
Member#: 7089
2016 STi
Basically the same. It's a 5 volt sensor. 5 volt power wire, ground wire, signal wire.
Closed TPS voltage should be between 0.4 - 1.0. Mine is 0.61
WOT TPS voltage should be between 3.5 - 4.5. Mine is 3.91
Austin is offline   Reply With Quote
Old 07-16-2003, 11:45 PM   #3
87fiveO
Member#: 39774
Hello,
Thanks,
I figured it was close to the same, so I set hers at 0.88V closed. it's somewhere around 4.5 open. Hers was set at around .43 closed before, must have been too low, kept tripping the MIL.
Thanks,
Derek
96 2.2l and 01 2.5l (rs) SOHC cam cogs shipjumper Normally Aspirated Powertrain 3 12-21-2006 07:30 AM
simple power mods - 96 2.2L Rebellion Normally Aspirated Powertrain 7 11-10-2004 04:41 PM
Will high flow cat work with 96 2.2L? 96Lconversion Normally Aspirated Powertrain 6 02-20-2001 08:35 PM
Would COBB tuning performance cams work with a 96 2.2L? 96Lconversion Normally Aspirated Powertrain 9 02-18-2001 09:27 PM
00 2.2L vs. 96 2.2L, where'd the power come from? 96Lconversion Normally Aspirated Powertrain 15 01-19-2001 12:32 AM
