Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-13-2003, 02:59 PM   #1
U.k.stu
Member#: 39059
1998 impreza S.T.i.
white
Default Exhuast help
How easy is it to remove my exhuast font pipes, its more the bit that goes to the turbo... Do i need special tools? Is it going to be Half an Hour or Half a day?
I have an H.K.S. system but i dont think that matters, its only so i can take it off to weld up a split..any advice would be great.
thanks Stu...
U.k.stu is offline
Old 07-13-2003, 03:37 PM   #2
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
There are 5 bolts holding the Downpipe to the turbo. There are probably tons of descriptions on how to do this in the archives here, but...
Basically, get stuff out of the way (intercooler, alarm buzzer, heat shield (lots of small bolts holding this on), etc.), then use a socket wrench, extension and 14mm sockets to remove the 5 bolts/nuts holding the downpipe one.
There are also 14mm bolts holding exhaust sections together and one holding the Downpipe to the transmission.
For a mechanically inclined person, it ought to take an hour or two.
Russ
rlavalle is offline
Old 07-13-2003, 04:51 PM   #3
U.k.stu
Member#: 39059
1998 impreza S.T.i.
white
thanks, Russ. will give it a go tomorrow night
U.k.stu is offline
Old 07-14-2003, 06:53 PM   #4
hatchy
Member#: 36852
2004 STI
Use plenty of Liquid Wrench. Those 5 turbo bolts took me a few hours.
hatchy is offline
Old 07-14-2003, 07:20 PM   #5
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Good Point. Turbo bolts and up-pipe bolts seem to be engineered to break easily. I sprayed them with penetrating oil the night before.
I've had 3 bolts that started loosening, then became stuck, then broke as the nut was forced off. Sigh.
The bolts & nuts are somewhat expensive. You might want to have a source handy in case one or two break.
Good luck,
Russ
rlavalle is offline
Old 07-14-2003, 07:33 PM   #6
happasaiyan
Member#: 37731
crap, was that on your STi?
i figured since its new, breaking bolts shouldnt be too much of a problem....doh...
happasaiyan is offline
Old 07-14-2003, 08:11 PM   #7
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
2 were on the WRX, 1 was on the STi.
Luckily, on the STi, it was a stud that broke near the top, so there was enough left to re-use.
I'm not sure what causes a bolt to break when the nut is already free. My theory is that as you loosen it, the wrench applies uneven pressure, causing the nut to become cross-threaded. It might be worthwhile to swap these nuts & bolts with good quality replacements.
Russ
rlavalle is offline
Old 07-15-2003, 04:54 PM   #8
U.k.stu
Member#: 39059
1998 impreza S.T.i.
white
Hay.. ! come on guy's. your doing a good job of putting me off.
Still haven't got round to getting the exhaust unbolted..although its had a good soak in penetrating oil. looking at it ,i wish i had smaller hands
U.k.stu is offline
Old 07-15-2003, 07:55 PM   #9
inchoate
Member#: 5470
2004 STi
blueish
if the nuts are breaking the bolts/studs you could try wire brushing the threads before you start to get rid of any rust/grime that may have accumilated in the threads. also a little wd-40 (or other spray lubricant of your choice) applied to the threads might be helpful.
inchoate is online now
Old 07-15-2003, 09:20 PM   #10
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Most likely, it'll go smoothly. Just be prepared for complications.
Do you have a second ride in case you're left with a broken bolt and need to go get a replacement?
Again, it's a pretty straight forward job.
Good luck,
Russ
rlavalle is offline
Old 07-20-2003, 01:17 PM   #11
U.k.stu
Member#: 39059
1998 impreza S.T.i.
white
2 hours to get it off !! no broken bolts, thanks to your help,
could of done with larger axle stands to get the front of the car right up in the air to twist the exhaust out. just got to weld it and put it back. I better do a good job, because im never taken it out again...NEVER !
U.k.stu is offline
help exhaust help! which one? xedordx Newbies & FAQs 6 09-01-2008 05:25 PM
Exhaust help please?? thebusiness999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-03-2001 04:31 PM
Need Exhaust help ASAP Witckraft Legacy Forum 2 08-21-2001 05:04 PM
exhaust help. M E R C U R Y Technical Forum Archive 3 10-12-2000 01:17 AM
too lean with carbon deposit on exhaust.... help???? tmaler13 Technical Forum Archive 3 09-06-2000 10:34 AM
