![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 29204
I am considering getting front and rear swaybars, with 21mm in the front and 23mm in the rear. I was wondering what effect, if any, will this have on driving my car in snow? I have 17" OZ Sls with Sumitomo HTR+ tires. Everything else is stock.
This might be a silly question but I don't want to compromise my car's handling in snow. Thanks
#2 |
Member#: 12455
Vehicle:02 WRX |
I would say yes. A bigger front is OK, but go over board on the back sway bar and your car would be very tail happy in the snow, even rain. On dry surface, people want the tail of the car to swing out (over steer) a little bit, but on compromised surface like rain and snow, over steer can be dangerous, IMO.
#3 |
Member#: 29204
Would 23mm in the rear be considered going overboard? What if I set it to 22mm? My goal is not to create oversteer, but to keep the car neutral.
#4 |
Member#: 11126
Vehicle:2002 Subaru WRX WR Blue |
I took A winter driving course last winter and the instructor took my car for a spin and found even the stock 22mm on my car too much.
I plan on getting an adjustable 20 22 24; 20 for winter and 24 for summer. Marvi |
#5 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
Anytime you stiffen the suspension (springs, sways) snow performance will get worse. I'm not saying that it will be bad though. I ran a Cusco 21 mm IIRC, and Cusco rear set to 24 mm all winter and never was concerned for my safety. I just didn't ever push it into corners (you shouldn't ever do that anyway in snow).
#6 | |
Member#: 7922
#7 |
Member#: 29204
Well, I never plan to push my car hard in the snow anyways. I guess i'm trying to figure out if reduced bodyroll will drastically reduce handling in snow, if driving "safely".
#8 |
Member#: 25255
Vehicle:2002 WRX MBP (I washed It) |
If you're making sudden and severe steering and or braking and accelerating inputs, like the type typically made in emergency situations the car will handle differently but no less prdeictably than stock. Its all about knowing how the car is going to behave and being prepared to deal with it. If you go out practice these types of manuvers in an empty lot you'll be much better prepared, no matter what you're setup. Generally speaking, however, at the limit, an understeering car is more forgiving than a oversteering car.
Later, |
#9 |
Member#: 8247
Vehicle:2004 STi JBP 1973 914 |
As long as you're not pushing your car even close to its limits, then you'll be fine. I have a RSB set at 24mm right now and I have not a problem. Snow and Ice are elements to be respected greatly, just take your time and you'll be perfectly fine. The HTR+'s are actually better than most in the snow as well. So no, there will not be a Drastic change in your normal drivability in snow.
-- Steve |
| Thread Tools | |
| Display Modes | |
| Electrical affecting engine performance | SchmisterTyler | Electrical & Lighting | 4 | 09-25-2009 03:24 PM |
| Does modified VB and TC on a 4eat affect AWD performance? | Alan l. | Transmission (AT/MT) & Driveline | 11 | 10-02-2006 07:56 PM |
| Could gas affect tranny performance? | nightdesigns | Legacy Forum | 1 | 12-23-2005 11:17 AM |
| Swaybar affect alignment? | FatCatTurbo | Brakes, Steering & Suspension | 4 | 06-30-2004 07:11 AM |
| How will modifications affect my insurance? | Sooberman | Newbies & FAQs | 12 | 04-08-2001 02:47 PM |
