Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-14-2003, 02:27 AM   #1
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
Default Wheels
i'm sure this has been asked before but i cant seem to find an answer, but how much do the stock BBS rims weigh (USDM)? im trying to find a rim i like for the car and if they are light enough then ill use the stocks for track and then buy some nice big ones for daily use. i hope the stocks are quite light. hehe
also wat is the biggest size i can fit (diameter and width)?
since it is an AWD car can i have a staggered set up?
and lastly how do i check to see if the wheel will clear the calipers?
JikJak is offline
Old 07-14-2003, 08:11 AM   #2
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
16-18 lb..
I'd call u stupid if u run staggered setup on STi
18-245 should fit fine (maybe need a spacer)..
Most aftermarket wheels dont fit on STi due to STi's huge brakes..
amdmaxx is offline
Old 07-14-2003, 09:35 AM   #3
wrx what
Member#: 19697
2008 WRX STi
get some Rota SDR or JDM V7 for track....
SDRs run around 600 shipped and the V7 are about double that price....
staggered = no no
wrx what is offline
Old 07-14-2003, 09:38 AM   #4
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
or SSR Competition..
amdmaxx is offline
Old 07-15-2003, 01:01 AM   #5
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
i like some of the volk racing rims
i just asked about the staggered thing 'coz ive seen some quattro owners do it
JikJak is offline
Old 07-15-2003, 06:46 AM   #6
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
According to SOA tech documents the BBS wheels are 15 pounds
DonA is offline
Old 07-15-2003, 10:31 AM   #7
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
That sounds like the optional BBS wheels for the WRX - are you sure, and which SOA documents?
ANZAC_1915 is offline
Old 07-15-2003, 12:18 PM   #8
WRXed
Member#: 3898
2004 WRX STi
White/gold
FWIW, this vendor lists the weight as 60 lbs. for a set of four:
http://www.subaruxtras.com/subarunav.htm
WRXed is offline
Old 07-15-2003, 01:28 PM   #9
LimeyWRX
Member#: 15953
04 Impreza WRX STI
Aspen White/Gold w/Stg2
the bbs wheels are a tad under 18lbs each without rubber.
LimeyWRX is offline
Old 07-15-2003, 03:27 PM   #10
T-WRX Racer
Member#: 21530
2004 STI--evo killer
[email protected]
SSR WILL NOT FIT!!!
I had a set test fitted on my STi. They WILL scrape the brake calipers.
Rota should have already release a wheel to fit the STI as of this week. That means I should get mine in a week or two. The wheels really look like prodrive rip offs. But they are perfect for R compounds at $175 a wheel.
Or you can have HRE build you some custom wheels.
T-WRX Racer is offline
Old 07-15-2003, 03:31 PM   #11
T-WRX Racer
Member#: 21530
[email protected]
Staggering isn't a good idea on AWD. Any AWD. It cause front and wheels to turn at different speeds that is not factored in to the equation. It causes undue friction and can (and probably will) cause drivetrain problems. But hey them wider tires on the back look cool don't they.
Remember Function before form every time.
I do love Volk's though
Old 07-15-2003, 03:45 PM   #12
wrx what
Member#: 19697
2008 WRX STi
what is the model name? what sizes? thanks
wrx what is offline
Old 07-15-2003, 05:12 PM   #13
thebishman
Member#: 38143
2004 STi
WRB/Gold
T-WRX Racer,
Can you supply any info. on the Rota wheel to which you referred above? Any link where I can see the wheel? I'm looking for a spare set of track wheels and need them soon.
I'm not familiar with Rotas. Are they relatively light weight? Even more important, are they strong as I don't want a wheel breaking at 120 mph on the track.
TIA,
thebishman
thebishman is offline
Old 07-16-2003, 05:23 AM   #14
WRX 2002
Member#: 11211
2004 STi
Rally Blue
I have 2 sets of SSR's if you would like to try them but unfortunatly they don't fit my STi without 5mm spaces.
N.
WRX 2002 is offline
Old 07-16-2003, 05:25 AM   #15
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Originally posted by thebishman
T-WRX Racer,
TIA,
thebishman
Rota SDR;s fit and fit well, not sure I would use them on the track due to a few wheels that I have heard about cracking. The weight of the SDR's is around 17-18 pounds.
N.
WRX 2002 is offline
Old 07-16-2003, 12:23 PM   #16
WRXed
Member#: 3898
2004 WRX STi
White/gold
WRX 2002,
Have you heard of failures of SDRs specifically? There was a bad batch of Attacks that Rota was very upfront about, but I've not heard of any other problems with any other Rotas.
WRXed is offline
Old 07-16-2003, 12:45 PM   #17
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Originally posted by WRXed
WRX 2002,
Your correct onlyh heard about the attacks, but at this stage I prefer to be cautious. The car is heavier than a WRX and is more powerful, just prefer to be safe.
N.
WRX 2002 is offline
FT: either 1 wheel for 1 wheel or 4 wheels for 4 wheels(read post) YaZahX Tri-State Area Forum 19 10-28-2002 05:47 PM
Wheels wheels wheels dasubaruguy Legacy Forum 4 10-23-2002 05:54 PM
wheels wheels wheels johnbe400 Brakes, Steering & Suspension 4 03-15-2001 02:17 PM
wheels wheels wheels johnbe400 General Forum Archive 2 03-15-2001 01:31 PM
