Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 07-14-2003, 08:13 AM   #1
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Default Remove Throttle Shaft from Throttle Body
What's the trick in getting the throttle shaft out of the TB? It doesn't want to slide out easily. Is the shaft pressed in the bearing and/or is the bearing pressed in the TB?
WRX, 03
WRX03 is offline   Reply With Quote
Old 07-14-2003, 03:14 PM   #2
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Right, that small pressed steel thing on the end opposite the TP sensor is just a seal. Behind it is a bearing pressed onto the shaft, and the whole lot pressed into throttle body.
I just pressed the shaft out and the bearing came too. I think some light heat from a carefully controlled blow lamp, or better a heatgun would make things easier.
I used a soft hammer, but press or large vice would be better. Give a tap and see if it moves any.
Paul
Pavlo is offline   Reply With Quote
Old 07-15-2003, 07:45 AM   #3
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Thanks
dbrier is offline   Reply With Quote
Old 07-15-2003, 11:04 AM   #4
WRX03
Member#: 20744
05 Baja Regal Blue
Thanks Pual, any problems bending the tap for sensor when tabbing it with a soft hammer?
Old 07-15-2003, 08:25 PM   #5
Quantum-Racing.com
Vendor
Member#: 20483
Try using a flat blade screwdriver on the base just back from the tab to avoid that. It shouldn't take enough force to hurt that portion.
Mark
www.Quantum-Racing.com
Quantum-Racing.com is offline   Reply With Quote
Old 07-16-2003, 05:14 PM   #6
WRX03
Member#: 20744
05 Baja Regal Blue
Thanks all for the info. Shaft came out fairly easily, just about dropped back in with a little heat and cold. TB looks REAL good, chucked it up in the lathe, did some tapering, and then finished it up with some 600 wet sanding. Milled down the throttle shaft to the depth of the original screws. Installed some button head screws. Owner was happy
Detaching throttle body from throttle cable..how? jcbluescooby Factory 2.0L Turbo Powertrain 4 11-03-2008 01:28 AM
low whine coming from throttle body area empeefivenavee Factory 2.5L Turbo Powertrain 2 03-26-2008 04:58 AM
Any tips on removing the tie rod shaft from the knuckle? PJC1909 Brakes, Steering & Suspension 4 06-16-2007 01:46 PM
Removing drive shaft from tranny... shadymilkman129 Transmission (AT/MT) & Driveline 4 06-20-2006 09:07 PM
High pitched noise from throttle body MarkRx Factory 2.5L Turbo Powertrain 6 11-27-2004 08:14 AM
