Old 07-14-2003, 11:53 AM   #1
AlanTheWoo
Member#: 19652
2002 BMW 330Ci
1997 BMW E36 M3
Default CEL & Error Code P0304
I noticed my car was leaking some oil, so I decided to change the oil on saturday morning. When i took off the oil drain plug, there were marks on the oil drain plug washer were it was tightened and one edge was as far out as possible and it that's where it was leaking from. I changed the oil and I gave it some time to check for new leaks, but everything seemed ok. So later in the day, I get in my car and when i drive off, I get a CEL and I scanned it with an OBD-II and it was a P304 Cylinder 4 misfire. Should I take my car to a dealership to check this out?
Alan
AlanTheWoo is offline   Reply With Quote
Old 07-14-2003, 11:55 AM   #2
AlanTheWoo
Member#: 19652
2002 BMW 330Ci
1997 BMW E36 M3
Update: The CEL light went away, but you can still scan for the code, I didn't clear it so the dealer could see it just in case. and my car is bone-stock, except for a boost gauge, at 14,500 miles
Old 07-14-2003, 12:53 PM   #3
vile
Member#: 32371
'02 t-rex wagon
platinum
if ur car is stock, and u have the time, take it in
vile is offline   Reply With Quote
EJ22T running rich, O2 sensor wires & error codes in all 4 injectors s'ko Legacy Forum 2 07-09-2008 08:26 AM
intermitent blinking CEL...no error code found dome Service & Maintenance 4 08-16-2007 09:47 PM
Here's a new one: MAF Error Code -- Transmission Error scooterforever Transmission (AT/MT) & Driveline 2 10-12-2006 07:06 AM
99 impreza Sport CEL error code 26 UK_SPORT Normally Aspirated Powertrain 1 08-23-2006 01:10 PM
CEL code p0304 deluxsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-29-2005 02:05 PM
