Old 07-14-2003, 08:01 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default what clutch?
I'm planning on installing a turbo kit in the next few weeks and am researching my clutch options. I have heard that the stock clutch will hold up just fine if I get a stronger pressure plate. Any advice on this? I'm planning on starting out with 4psi and possibly working up to 10psi in the future. What do you guys recommend, and what kinda prices am I looking at?
lotusTT is offline   Reply With Quote
Old 07-14-2003, 08:21 PM   #2
insanesuby
Member#: 23494
2013 WRX
I run 6psi and a ACT street/strip clutch. Stiffer pedel but no harsh clutch enguagment. I believe I got mine for $320 for whole kit. Disc, pressure plate, and alignment tool. I run it with the JUN flywheel.
insanesuby is offline   Reply With Quote
Old 07-14-2003, 10:13 PM   #3
kaos200
Member#: 2692
my personal opinion leans away from the ACT for subarus. Ive just seen/heard of too many breakages (na and turbo) when used with those clutches.
kaos200 is offline   Reply With Quote
Old 07-15-2003, 02:39 AM   #4
trilap5e
Member#: 19644
2005 WRX STi
I just installed (last saturday) and ACT Street setup - 304lb/ft of torque capacity and already love it. i drove to cali that nite and had to deal with la traffic the next morning, no problems. the clutch does grab harder and the pedal pressue is noticibly stiffer (ok by me). it's not a harsh start and easy easy to slip. i'm all for it!
trilap5e is offline   Reply With Quote
Old 07-16-2003, 02:03 AM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
the Excedy has a light pedal and is gentle on the tranny. However dont expect to run alot of power through it. 7-8psi is probably the max Id reccomend it for. (not slipping at 6.6 though)
Midwayman is offline   Reply With Quote
Old 07-16-2003, 05:45 PM   #6
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
thanks for the info guys. any comments on a stock clutch with stronger pressure plate?
Old 07-16-2003, 07:49 PM   #7
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
FWIW both excedy and act use stock disks unless you specify otherwise. Its just a stronger plate on both.
-B
Old 07-17-2003, 04:00 PM   #8
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Lotus... you have to upgrade your clutch. Most turbo setups, even mild ones will require it, thanks to goobs of extra torque.
I have had the Excedy13lb flywheel and ACT clutch setup for around 2 years now. The only problem experienced so far has been a bent fork. My car and tranny have survived many runs at the strip.
I think the key to longer tranny life is the lighter flywheel. You should seriously consider swaping in a lighter flywheel while you change your clutch anyway. That way you get the power down to the road.... and not totally trash your tranny in the process.
Rich L is offline   Reply With Quote
Old 07-17-2003, 04:30 PM   #9
Tats
Member#: 5692
WTF? YES! I am
better than you!
Exedy Clutch and 13lb flywheel here...6-7 psi and no complaints at all.
tats.
Tats is offline   Reply With Quote
Old 07-18-2003, 10:38 AM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Exclamation
don't get a Clutchmaster.....mine died in less than 10K miles
it was broken in properly, not drag raced on and only running 200 lb/ft of torque
I now have an Exedy clutch/flywheel, I like it so far
Scoobyslack1 is offline   Reply With Quote
Old 07-19-2003, 06:30 PM   #11
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
i have a act and the peddle is stiff, not that bad. also it only has a ruff engagment sometimes. other times its just right
scoobyimpreza is offline   Reply With Quote
Old 07-19-2003, 10:37 PM   #12
halftendril
Member#: 27802
2000 impreza 2.5rst
get the act street clutch kit, it works really well and is hardy stiff at all
halftendril is offline   Reply With Quote
Old 07-19-2003, 11:24 PM   #13
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Excedy clutch,Feels OEM because it is, (stock clutch is excedy) No slipping at 5psi,Upping the boost with a larger turbo soon though
Anyhoo,install the clutch before the turbo and do a flywheel at the same time,also replace the bearings at that time as well..
Ben,
EMERGENCY help:1/2way through the first L>LGT swap-what clutch fork for cable clutch? greddy18 Transmission (AT/MT) & Driveline 5 07-28-2009 10:29 AM
what clutch to go with N/A setup? imprezey Transmission (AT/MT) & Driveline 23 02-07-2003 03:03 PM
what clutch/flywheel combo is everyone running? Mr.Freeze Transmission (AT/MT) & Driveline 2 10-04-2002 10:01 AM
What Clutch? Midwayman Mid West Subaru Owners Club Forum -- MWSOC 9 09-09-2002 04:24 PM
what clutch to purchase Tensecgn Normally Aspirated Powertrain 4 02-11-2001 03:39 PM
