Old 07-14-2003, 10:32 PM   #1
GrynReaper
Member#: 39845
1999 Impreza RS
Default Rear wheels not turning on my AWD!
I have a '95 L Coupe. It's was AWD when I bought it. It has other plans...
No, smoke, sounds or drama. It just didn't feel right the thru the corners. I suspected that the only power I was getting was from the front wheels. When winter came, my fears were confirmed. It was obvious that the rear wheels were not turning under power. So I put it up on jack stands and looked. The whole drive shafts isn't moving!
Does anyone have any ideas for what's going on? Is there a common problem with a fix?
Good news only please.
GrynReaper is offline   Reply With Quote
Old 07-14-2003, 10:45 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Post this in the transmission forum for better answers...
Automatic or manual?
Old 07-14-2003, 11:27 PM   #3
GrynReaper
Member#: 39845
1999 Impreza RS
Default Follow up information on the 2wheeled wonder
It's an automatic. (couldn't pass up the car in spite of the slush box)
Old 07-15-2003, 01:38 AM   #4
CharT
Member#: 36117
2003 WRX Wagon
If it's automatic, is it an electronically controlled center differential? If so, maybe you just blew a fuse. I'm sure someone can tell you where the differential fuse is and you can check.
CharT is offline   Reply With Quote
Old 07-15-2003, 07:13 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
A fuse would put it in 2wd, the dash would illuminate the FWD mode.
Old 07-15-2003, 07:48 PM   #6
GrynReaper
Member#: 39845
1999 Impreza RS
I went throught all the fuses. The 10 amp fuse that goes to the tranny is fine. I also checked the "2WD" fuse in the engine compartment and it does not have a fuse. (Which, as I understand it is what I want).
So I went to go see how much a Subaru Factory manual would be... Is anyone interested in giving me a scholorship/donation of $250?
I don't see any unplugged wires or anthing like that leading to the tranny/diff. It just flat stopped working. The drive shaft does not move at all.
Old 07-15-2003, 09:01 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
You could test if it was electronic or mechanical. Cut the wire to the solenoid that controls lockup. If you get a locked center differential then its electronic. If the rears still stay still then your problem is mechanical.
Does your power light or transmission temperature light ever flash?
Old 07-16-2003, 03:43 PM   #8
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Double post, where's the moderator police?
SubyTechMaster is offline   Reply With Quote
Prosport premium gauges not turning on on 05 WRX! madrex26 Electrical & Lighting 6 04-06-2008 08:03 PM
Help! Subs not turning on and radio not coming in. candronaco Car Audio, Video & Security 8 07-14-2007 02:47 PM
all wheels not turning need opinion asap!! joefitz Transmission (AT/MT) & Driveline 6 11-25-2005 06:14 PM
Friends fuel pump not turning on? kaos200 Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-14-2004 10:25 PM
AMP Stopped, not turning on. billybob3 Car Audio, Video & Security 27 02-17-2004 01:19 PM
