07-15-2003, 10:14 AM | #1 |
Member#: 36448
VIC
grounding mod vs warrenty
im really intrested in doing the grounding mod on my car next, but i am worried about the warrenty being void becuase of something like that. do any of you have any experience with this?
Thanks alot ~SGD
07-15-2003, 07:36 PM | #2 |
Member#: 36448
VIC
guess not.
~SGD |
07-16-2003, 03:02 PM | #3 |
Member#: 36099
Vehicle:'02 rex silver |
I have the DIY grounding mod and I'm taking my car in for warranty work for the tranny. Didn't say a thing about it. Shouldn't effect it at all. Unless it's something electrical that goes wrong, then they might blame that. hope this helps
07-16-2003, 03:08 PM | #4 |
Member#: 36448
VIC
thanks, im gunna ask the service guys for a official answer just to make sure.
~SGD |
07-16-2003, 10:12 PM | #5 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
Stop this silly thread now!
There's no way a grounding mod is going to affect warranty coverage (unless you "ground" to the positive terminal of the battery or something equally stupid). Also, whatever the service guy says won't matter unless you get it in writing, and no one in their right mind at the dealer will give you something like that in writing. |
07-17-2003, 03:49 PM | #6 |
Member#: 7193
Vehicle:MY02 WRX Blue |
If you are worried about it just improve on the stock grounding points. Don't think its really the wires themselves, probably just bad chassis mounting points.
just my opinion, anyways.... -anders |
07-17-2003, 03:59 PM | #7 |
Member#: 15106
aov-yah, i agree. the strut top bolts are real good grounding points so i found out.
07-19-2003, 12:33 AM | #8 | |
Member#: 36448
VIC
Thanks for the other replies....they helped. ~SGD |
07-22-2003, 05:22 PM | #9 |
Member#: 37583
just remove it when u take it in, takes 5 min. dont need the ristk
07-22-2003, 09:34 PM | #10 |
Member#: 10309
NWIC
Sorry about the harshness SGD, but the real world is harsh at times.
I was trying to make two commonsense points that are often overlooked by newbie modders: 1) If you don't understand the theory behind a mod and what the mod does, you shouldn't be doing the mod. Anyone who understood what a grounding mod is would realize that it's about as likely to damage anything as would changing the paint color on the car. 2) Anything the dealer/"official" technician *tells* you (not in writing) will not in practice be binding upon them, unless you have a tape recording of it, or a bunch of credible witnesses that they said it. No dealer/technician in their right mind would tell you *in writing* that any mod that you do will not void the warranty, because they have no control over how you do it. Conclusion: Because of (2) above, nobody can tell you with *authority* that any given mod will not cause warranty problems. Thus, you and only you can decide whether you want to risk your warranty by doing a specific mod. So (1), you'd better understand exactly what the mod does before you decide to do it. Have fun with your mod! |
07-22-2003, 09:49 PM | #11 |
Member#: 11202
Vehicle:2009 Infiniti G37X Prev: 2006 STi with stuff |
Should be ok as long as the techs see black wiring and not red. You'd confuse them.
07-23-2003, 07:02 PM | #12 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Subaru of America included the following notice in this month's newsletter it sends to all dealers' service departments:
07-23-2003, 09:27 PM | #13 | |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
07-24-2003, 01:17 AM | #14 |
Member#: 36448
VIC
those are very helpful posts thanks alot.
i knwo what this mod does however im not positive as to what effects it can have other than performance. i guess i have not done enough homework yet. i dont plan on doing the mod for a while. so in the meantime im gunna research it more. thanks again ~SGD |
07-24-2003, 09:43 AM | #15 | |
Member#: 25254
Vehicle:2003 WRX wagon |
So to answer the original question, this quote would imply that yes, you should go ahead and do the grounding mod. But if you ever get a problem that might be remotely attributable to electrical problems, the dealer may ask you to undo the grounding mod before going ahead with any additional diagnosis work. |
07-24-2003, 06:06 PM | #16 |
Member#: 40500
TXIC
Vehicle:16 Forester XT |
Unless SOA is providing free replacement air filters/cartridges, the Magnuson-Moss Warranty Act of 1975 prohibits vehicle mfgs and dealers from voiding your warranty for using aftermarket items like the K&N filters.
07-24-2003, 06:15 PM | #17 |
Member#: 10309
NWIC
No, the M-M only applies to aftermarket items *that meet OEM specs*. There has been some good evidence that K&N filters let through more particulates than the OEM air filters, so they may not meet the OEM spec. I believe K&N has a warranty on the use of its filters, but you may end up having to rely on that instead of the Subaru warranty.
07-25-2003, 09:10 AM | #18 | |
Member#: 25254
The quote only says that for ease of diagnosis, it is best to return everything to OEM state. That's all! Presumably, you can put back that K&N filter after the diagnosis has been finished (and assuming that replacing the K&N filter with an OEM filter did nothing to aid the diagnosis). |
Cd/DVD player vs. warrenty | ETown | Car Audio, Video & Security | 7 | 07-30-2007 07:18 PM |
Single-point ground mod vs. Multi-point ground mods | DrBoy01 | Normally Aspirated Powertrain | 5 | 12-05-2003 04:21 PM |
Stock restrictor vs 3/16" vs Grounding Mod revisited | 98kPa | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 06-05-2002 12:14 AM |
Stock restrictor vs 3/16" vs Grounding Mod *revisited* | 98kPa | Bay Area Impreza Club Forum -- BAIC | 0 | 06-03-2002 01:50 PM |
Battery Connections & Grounding Mod | JenisonWRX | Electrical & Lighting | 10 | 02-18-2002 11:01 PM |
