Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 04-12-2001, 07:02 AM   #1
TortoiseAWD
Member#: 5223
2002 Impreza WRX
Silver Metallic
Question "Check Engine" and EGR valve
My '92 SVX is throwing an intermittent "Check Engine" light . . . my mechanic pulled the codes, and the ECU flagged both knock sensors, both O2 sensors, and the EGR valve. My mechanic suggested that the EGR is probably causing the knock and o2 codes (which, given my limited computer-geek's knowledge of what the EGR does, makes sense). There is no noticeable change in performance when the light pops on, and it usually flickers back off within 10 seconds or so.
Does anyone out there have the shop manual? What are the procedures for checking out the EGR? I have my fingers crossed that it will be as simple as pulling the valve and cleaning it up with throttle body cleaner, but fate is rarely that kind to me when it comes to vehicles
Thanks in advance for any help,
Scott
'92 SVX
'92 Talon TSi AWD (12.797 @ 107.13)
TortoiseAWD is offline
Old 04-12-2001, 09:30 PM   #2
CRZ_MSL
Member#: 1610
Post
Is your mechanic a Subaru trained tech, or just a generalist?
There is a diagnostic port on the SXX that you can plug a tool into that might giver you more info.
On the 1994+ models it is next to the steering wheel, exactly where the change hold is on the earlier SVX models. (+
CRZ_MSL is offline
Old 07-20-2001, 01:07 AM   #3
Blindeye_03
Member#: 4418
2016 Focus ST
EGR is the way that your engine recirculates its own exhaust gas to lower emissions. Its like hooking a tube to your ass and connecting it to your nose and then farting.....keeps from letting the gas out and all it does is harm the engine.
Blindeye_03 is offline
Old 07-20-2001, 05:13 AM   #4
Flatfour
Member#: 906
Talking
lol.. That is clearly the best analogy for what the egr does that I have ever heard...!
Flatfour is offline
HTML code is On
Check engine and cruise control light on TENAZ Engine Management & Tuning 6 03-13-2007 01:16 PM
check engine and flashing cruise Subie 45 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 03-15-2006 11:03 AM
Any body ever have check engine, and cruise control blink? stealthblksti Subaru Conversions 1 08-19-2005 11:15 AM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 11:47 AM
MY 2000 Check Engine, and Moonroof Vibrations Swivel1000 Technical Forum Archive 5 07-08-2000 09:34 AM
