Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 07-15-2003, 07:18 PM   #1
d4d4d4d4
Member#: 38925
1990 legacy wgn
Pig blood for paint
Question Simple Q. -- Is my knock sensor in right?
I located the knock sensor in my phase 1 ej22. I wanted to know how far the sensor should go into the block. As it is now, there is a large part shaped like a nut that looks glued directly to the engine block. Then there's another bolt with the wire hooked into it going straight into that. The second bolt is about 1/2 an inch from the bottom nut thing. Is this where it should be, or should I try and tighten it all the way down?
I've been trying to fix a problem with an over active knock sensor, so should I just go and buy a new one?
thanks
d4d4d4d4 is offline   Reply With Quote
Old 07-15-2003, 09:03 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You are probably looking at the wrong item. The knock sensor is a ring, aproximatly 1 inch in diameter and 3/4 inch tall with a single 12mm bolt through the middle. The electrical connection is white or grey and has a single lead, the wire is about 4 inches long and snaps to a spot right below and to the right of the throttle plate.
I R teh stupids: There is only one knock sensor in EJ25..true or false? kaisersouse Normally Aspirated Powertrain 1 10-22-2006 03:04 PM
Is a knock sensor necessary on an NA car? tooocool49723 Normally Aspirated Powertrain 7 02-01-2005 11:15 AM
Where is the knock sensor? SubaruGenki Normally Aspirated Powertrain 5 08-18-2004 12:07 PM
i think my knock sensor is causing me to detonate. possible? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-27-2003 05:42 PM
I think i fixed my knock sensor problem....my dealer sux.!!! Aaron'z 2.5RS Normally Aspirated Powertrain 8 01-09-2001 04:25 AM
