07-15-2003, 09:03 PM | #1 |
Member#: 16731
Vehicle:2002 Impreza WRX WR Blue |
About to hardwire my radar, some final questions?
Hey guys, I am about to hardwire my valentine by the instructions onon this site and I want to know if this wire they tell me to tap (I dont have the dimming mirror) is a constant power source, or if it turns on and off with the ignition, which I would prefer. Also how do I get the cord for the radar through the headliner?
-Thanks
07-15-2003, 10:18 PM | #2 |
Member#: 33410
Vehicle:08 wrx dgm |
it's w/ accessory start. so you will be ok.
07-16-2003, 12:00 AM | #3 |
Member#: 28631
Vehicle:2002 WRB wrx wagon AVO stg I,II Shiv ECUtek |
thats how i wired my V1. your detector will turn on and off with the ignition key. I stuffed my wire bundle to the left side of the domelight. I pulled just about 3-4" of the power lead out of the front edge of the headliner and mount my detector right above the mirror. Make sure it sits level. Only drawback I can tell is that I suspect that drivers behind you can see your display, unless you have the remote display unit which will cause the lights on your detector to be turned off. The plusses are that your V1 will have excellent front/back/side reception
07-16-2003, 01:39 PM | #4 |
Member#: 16731
How did you get the wire under the headliner? Can I just move it over, or is it sealed or something?
-Thanks |
07-16-2003, 02:26 PM | #5 |
Member#: 11221
Vehicle:2002 2.5 RS Black as Midnight!!! |
The headliner is jsut clipped to the roof. The dome light and the little visor above the rearview are the main supports
Remove all the visors up front, and you can stick your hands in if you want to run power down the A-Pillar. |
07-16-2003, 04:05 PM | #6 |
Member#: 16731
Thanks guys, I just have one more question, did you attach the 2 grounds to the left and right visor clip things like in the link? If so how did you screw it down?? It looks like there is barely any room at all, to get your hands in there?
-Thanks |
07-16-2003, 06:21 PM | #7 | |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
07-16-2003, 07:13 PM | #8 |
Member#: 16731
I dont know how to do that, the black grounds came with metal ends that go around bolts, are you suggesting I cut these off and splice into the ground wire, both of the wires too? Also whic one is the ground?
-Thanks |
07-16-2003, 08:52 PM | #9 | |
Member#: 22412
SWIC
Ground is the black wire (black is almost always used as ground... except in power cables for computers and such) |
07-16-2003, 10:36 PM | #10 |
Member#: 16731
I took out the map lights an hour ago to see what was there, and there was a plug, which was unplugged, is this for the auto dimming mirror? Also can I ground the radar to the 2 screws that hold up the map lights?? I have pics but I cant acess my webspace right now, ill try to post them up asap.
-Thanks |
07-16-2003, 10:40 PM | #11 | |
Member#: 16731
-Thanks |
07-16-2003, 11:26 PM | #12 | |
Member#: 22412
SWIC
07-16-2003, 11:31 PM | #13 | |
Member#: 22412
SWIC
You can try to ground to those screws, but you want to make sure you have good metal to metal contact at the ground point and those screws don't really lend themselves to that (there are others which you could use - but nothing really accessible under the headliner) - by tapping an existing ground in the harness, you get that taken care of automatically. |
07-17-2003, 10:02 AM | #14 | |
Member#: 16731
-Thanks everyone Im going to try this after work and see what happens. |
07-17-2003, 04:25 PM | #15 |
Member#: 16731
Bump...
07-17-2003, 09:49 PM | #16 |
Member#: 28631
just use the clip on the end of your V1 ground wire and do like the link u referred to above showed. IT is a really easy install and I am not sure why it is giving you fits. The 3 wire plug is for the auto dimming compass mirror. Mine was taped in a bundle as I didn't have the accessory mirror once upon a time. when the center visor and the maplight is out, you can poke the radar connector out the frontside of the headliner which is kinda like egg carton material. Just dont pull the headliner down far as it could kink on you. You can dooo it
07-17-2003, 10:43 PM | #17 | |
Member#: 16731
Everyone thanks for your help. |
07-20-2003, 04:37 PM | #18 |
Member#: 36505
TXIC
Vehicle:2004 Forester XT PSM 2007 Acura RDX w/Tech CBP |
I also did this on my wife's new XT. In the XT, there is a metal strut that runs from the front to the back. It has two screws visible with the headliner console off, so I used on of them to ground.
We are now a hard-wired V1 2004 Subaru turbo family |
Best place to hardwire a radar detector in '07 Impreza? | mjthor | Interior & Exterior Modification | 43 | 08-27-2008 06:52 PM |
some final questions about open source/tactrix tuning | JasonLI25T | Newbies & FAQs | 11 | 08-21-2008 12:33 PM |
About to modify my 4eat - need some last minute questions answered | Ronnzi | Transmission (AT/MT) & Driveline | 4 | 09-21-2006 11:19 AM |
I want to hardwire my Sensoro(crap) Radar detector | billybob3 | Electrical & Lighting | 11 | 08-09-2004 02:52 PM |
Instructions: How to hardwire a radar detector. | paultg | Car Audio, Video & Security | 0 | 08-31-2002 06:06 PM |
