Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 04-13-2001, 11:06 AM   #1
Jgrahn555
Member#: 3224
Post High Compression
I don't own an SVX, but i'm wondering if any of you have upped the compression on your 6 cyls. What method did you use to do it?
Thanks in advance.
Jason
Jgrahn555 is offline
Old 04-13-2001, 11:36 AM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I haven't done so, but I imagine that you could do it with new pistons....
kastle is offline
Old 04-13-2001, 02:30 PM   #3
CRZ_MSL
Member#: 1610
Post
That is exactly what I am talking about. Right now there is X distance between the maximum reach of the piston and the maximum reach of the valves. Increasing compression ration requires an increase in how close the piston gets to the valves. If it gets close enough, it becomes an interference.
This is not a bad thing, as long as your timing belt does not break. I think all Honda engines are interference.
CRZ_MSL is offline
Old 04-14-2001, 12:32 AM   #4
CRZ_MSL
Member#: 1610
Post
I don't know of anyone who has taken apart thier EG33 (SVX engine). I would imagine that if you were to do this it would be byu swapping out the pistons.
The EG33 is a non-interference design. Upping the CR too much will change that.
CRZ_MSL is offline
Old 04-14-2001, 12:54 AM   #5
Jgrahn555
Member#: 3224
Post
>>>The EG33 is a non-interference design. Upping the CR too much will change that.<<<
This I've never heard of happening on any non-interference engine ('course, i haven't heard all that much to begin with).
How does upping the compression ratio too much make it an interference engine? are you talking about valves hitting the piston or valves hitting valves?
Are there any books concentrating on high compression? Any web pages devoted to it?
Thanks again.
Jason
Old 04-14-2001, 10:59 AM   #6
Blindeye_03
Member#: 4418
2016 Focus ST
Post
I have never even seen an svx before...
Blindeye_03 is offline
Old 04-14-2001, 11:08 AM   #7
MrHorspwer
Member#: 4063
Post
Most engines right now are non-free spin, or interferance, motors. If you break a timing belt or chain, you have a bunch of bent valves or, worse yet, ventilated pistons. The easiest way I would think to raise the CR is to resurface the heads. I don't think many people have done this so you'd have to be very carful with valve to piston clearence. I'm not familiar with how the tension is kept on the timing belt so you'd have to keep into consideration not to take too much material off and lose tension and change the cam timing.
MrHorspwer is offline
Old 04-16-2001, 12:31 AM   #8
Jgrahn555
Member#: 3224
Post
>>The easiest way I would think to raise the CR is to resurface the heads. <<
I thought about doing this, but in the subaru, if you mill the heads down to much, the intake manifold won't fit. In all my research, i'm thinking that the only way to up comression safely is by new conrods and pistons.. Any other ideas?
HTML code is On
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 31 05-18-2006 04:06 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 10:55 AM
random thoughts on high compression turbo engines HamFist Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-23-2002 01:16 AM
Tuning hp and torque curve w/ low compression and high compression pistons FuJi K Normally Aspirated with bolt-on Forced Induction Powertrain 22 10-14-2001 07:25 PM
High compression pistons for NA? bsquare Normally Aspirated Powertrain 7 04-07-2001 10:56 AM
