#1 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
I bought a set of the Subaru rubber floor mats (PN J5010SS300) for my WRX. I took out the WRX floor mats and put these rubber ones with the deep channels in their place. The rubber mats work great with respect to catching/draining mud/snow from shoes, etc., but they have this tendency to creep toward the front of the car with a resulting bunching up beneath the pedals unless I reposition them every day.
Does any else have this problem? The original WRX driver's side mat hooked onto a floor peg to prevent creep, whereas the rubber mat does not have any provision to utilize the floor peg. Has anyone figured out a system to anchor the rubber mat from this peg? [Fixed part number] [This message has been edited by Jon [in CT] (edited May 19, 2001).] |
#2 |
Member#: 2918
Vehicle:2002 Impreza WRX Silver Sedan |
My car also came with the rubber floormats. The dealership guys put them ontop of the stock floormats. This might be the solution you need. They stick pretty well to the stock floormats and cover them effectivly.
#3 |
Member#: 5575
Vehicle:'02 Impreza WRX Midnight Black Pearl |
I hired a midget to hold mine in place.
(I am SO going to hell) |
#4 |
Member#: 6534
My car has posts to keep the floor mats in place.
#5 |
Member#: 710
Vehicle:2000 Impreza 2.5RS SRP |
I put velcro on the bottom of my floor mats, just a tiny bit.
However, I used the wrong adhesive, and the velcro stuck far better to the 'carpet' on the RS than the floor mat. Next time I'll use a staple or something more positive, and maybe try to find a weaker velco knock-off. For now I'm back to it slipping around. I also custom-cut the mat to fit perfectly, this restricts where it wants to go a lot. Consider cutting the mat so it goes over the hook. |
#6 |
Member#: 3776
Vehicle:Take a wild guess |
Jon,
Yeah I got the same problem. You know how the stock driver's mat comes with a whole that attaches to that small floor post? I took a small piece of steel plate and drilled two wholes on it. One is secured to the rubber mat by nut and bolt, the other I pushed into the floor post. It works pretty well. |
#7 |
Member#: 6582
Vehicle:2002 WRX WR Blue |
Hmmmmmmm......
The stock mats have two holes on the trailing edge, but only one post to locate, right? Flip stock mat upside down, and locate on post using second hole. Now underside of stock mat is exposed. Will additional rubber mat be secured by all the little rubber fingers on the top (original underside) of the stock mat? |
#8 |
Member#: 6482
Vehicle:2002 WRX Wagon Midnight Black Pearl |
I've seen clips that have two long prongs on one end to stick into the carpet and then you clip your mat to those. No idea how they would look. Check stores like Wal-Mart or K-Mart if the idea intrests you.
#9 |
Member#: 145836
Vehicle:2004 Impreza WRX Platinum Silver Metalic |
I had the same problem.
I fixed it by attaching a piece of plex to the bottom of the mat with double sided tape, and some pop rivets. I used a rubber grommet to hold the hole in the plex to the peg. |
#10 |
Member#: 16696
Vehicle:'02 MBP WRX Sedan Ooh, you touch my TraLaLa |
