Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 07-16-2003, 12:24 PM   #1
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default doing 30K personally, need some advise
Ok, time for the friend's 30K overhaul. What I understand is done is:
brake fluid flush
oil/filter
coolant flush
tranny flush
rear diff flush?
Is this it?
WIth the brakes, I've done lines before as well as new willwood calipers on my wrx. Am all I am doing is pulling one of the brake bleeders and draining the system through it, making sure the brake reserviour doesn't run dry as I add more. Do I need to do this every corner?
Oil and OE filter is no problem to do.
I've already done the coolant.
Here is my other question, when flushing the tranny fluid is it essentially as simple as the oil? Just unplug and refill or is there an order of flushing? I know the bleed order when finished.
All I know on the rear diff is that the drain plug takes about 150lb ft to get off Is this a required part of the 30K service?
Did I miss anything? Thanks for any help given. I'll be doing some of this today, at least the oil/fiter.
IA Performance is offline   Reply With Quote
Old 07-16-2003, 01:31 PM   #2
mhbrown
Member#: 12537
'02 WRX Sportwagon
WR Blue Pearl
Default Re: doing 30K personally, need some advise
brake fluid flush
oil/filter
coolant flush
tranny flush
rear diff flush?
Is this it?
WIth the brakes, I've done lines before as well as new willwood calipers on my wrx. Am all I am doing is pulling one of the brake bleeders and draining the system through it, making sure the brake reserviour doesn't run dry as I add more. Do I need to do this every corner? Reply: Yes, every corner. Bleed until you can tell you have new fluid coming through. It should take just under a litre; but I have never been able to do it without getting into the second litre.
Here is my other question, when flushing the tranny fluid is it essentially as simple as the oil? Just unplug and refill or is there an order of flushing? I know the bleed order when finished. Reply: Manual tranny, I assume. Just drop the plug and drain. Fill up with 3.8 qts of your favorite gear lube -- tons about this on site. Get a funnel with a flexible extension because the filler hole (dipstick) is in a tough place. Bleed order????
All I know on the rear diff is that the drain plug takes about 150lb ft to get off Is this a required part of the 30K service? Can't remember. I got mine off fairly easily, though. Just remember to open the top fill before you open the bottom drain. If you empty the diff and then can't get the fill plug off, then you are in trouble.
mhbrown is offline   Reply With Quote
Old 07-16-2003, 01:46 PM   #3
IA Performance
Member#: 25194
Dark Gray
Thanks for the reply. The bleed order was meant to go under the brake area
Lastly, I'll be recylcling the body fluids. Auto zone takes oil, what about tranny fluid? Brake Fluid?
Old 07-16-2003, 05:22 PM   #4
mhbrown
Member#: 12537
'02 WRX Sportwagon
WR Blue Pearl
They take them all where I am from.
Old 07-16-2003, 07:28 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I generally use a turkey baster or large syringe to suck the old fluid out of the resevior directly, then fill it up with new fluid and bleed each corner until the old fluid in the line is flushed - you want to clear the old fluid out of the calipers since as it ages and takes on water, it becomes increasingly corrosive to the internals - so you do bleed each corner, but no need to flush the entire resevoir through any of them.
Old 07-16-2003, 11:18 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
It helps if the transmission and diff are still warm, because their fluid is thicker than normal oil. Just drain them and refill; I'd let them drain 15 or 20 minutes before reinstalling the plug.
Don't forget to flush the clutch fluid just like the brake fluid (remove old from reservoir, add new, bleed at slave until all fresh fluid).
I'd change the power steering fluid, too (sorry, haven't done that yet myself).
Also, change air filter and (if you have one) cabin air filter.
As for fluid disposal, stores around here only take motor/trans oil. Coolant & brake/clutch fluid have to go to the city hazardous waste center.
Old 07-18-2003, 09:04 PM   #7
IA Performance
Member#: 25194
Dark Gray
ok, this am I finished so far is:
Oil/filter change
Brake fluid exchange
Coolant exchange
Air Intake filter replaced
Fuel filter replaced
Tires balanced/rotated
I looked in the book in regards to teh tranny and diff and stated only to inspect. This is for a stock wrx (not mine) and she babies it around town. Not sure if a tranny flush is worth the time as with the diff. She is going to mexico for a year with the car though and I want to make sure every service part is done before she departs.
Old 07-18-2003, 09:12 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Did you replace the thermostat?
Old 07-18-2003, 09:51 PM   #9
IA Performance
Member#: 25194
Dark Gray
I did on mine but not hers. Hence not doijng a complete flush. CRAP. That didn't make any sense till I hit reply. Is that what you meant?
Old 07-18-2003, 10:02 PM   #10
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
What is the dealer charge for a 30K mile service?
Neek is offline   Reply With Quote
Old 07-18-2003, 11:23 PM   #11
IA Performance
Member#: 25194
Dark Gray
I believe they charge $300. Total cost is maybe $100 with all new filters and fluids and plugs. If I wasn't proficient with Imprezas I probably would have sent her to the stealer, I mean dealer
Old 07-21-2003, 12:54 PM   #12
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
Last weekend I changed the oil, front and rear diff fluids, and tranny fluid on my wife's Legacy GT wagon (4EAT). I had no real problems except that you really can't "flush" the tranny. You only get about 50% of the fluid out because the torque converter ends up holding the other 1/2 and the only way to get that out is by pressurizing the system. Also, I couldn't get the drain plug off the rear diff, so I just snaked a vacuum line in the fill hole and removed the fluid with my Mity Vac.
Dave
MaddMax is offline   Reply With Quote
Old 08-11-2003, 01:07 AM   #13
Prince Ali
Member#: 19630
Platinum Silver
Where are the reservoir and slave for the clutch system? Do I need a special fluid for the clutch?
Prince Ali is offline   Reply With Quote
Old 08-15-2003, 03:26 PM   #14
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
Default Cluch Fluid
I beleave the cluch system uses ordinary brake fluid, DOT 3 or better. If you are using premium fluid in the brakes you might as well use it in the cluch system too.
Fred
fredj is offline   Reply With Quote
Old 08-18-2003, 06:21 PM   #15
en3d
Member#: 5238
GGA Black
I would also change the fuel filter.
en3d is offline   Reply With Quote
Old 08-19-2003, 12:29 PM   #16
BeeGee
Member#: 27724
1970 F100
Black/White
How much is she planning to drive in Mexico? They don't sell Subarus there, so I would send a few oil/air filters with her as well. It could be a pain and/or expensive to get parts otherwise.
BeeGee is offline   Reply With Quote
Old 08-20-2003, 12:28 PM   #17
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
good idea!
djerickd is offline   Reply With Quote
Interested in some coilovers, need some advises Lordhowe Brakes, Steering & Suspension 21 02-16-2006 04:17 PM
New to the club, need some advise on suspensions ZMANNH25rs Brakes, Steering & Suspension 3 08-17-2001 03:05 PM
Need some advise! :) Tigo Newbies & FAQs 1 04-17-2001 07:26 PM
I need some advise about stickers Boom New England Impreza Club Forum -- NESIC 5 06-16-2000 10:27 AM
