Old 07-16-2003, 06:52 PM   #1
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
Default Where are you getting Vaccum Lines?
Im having a hesitation problem under boost and i suspect that its because i have the vaccum lines for the boost gauge, RRFPR, J&S, and the BOV and wastegate teed off the same line which comes from where the cruise control vaccum line used to go. Where else can I run a vaccum line that sees boost?
Derk1127 is offline   Reply With Quote
Old 07-16-2003, 07:28 PM   #2
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
I see you posted the question before me. Thanks Derk.
Turbotegra is offline   Reply With Quote
Old 07-16-2003, 09:21 PM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ257
Brilliant Red
Default Search and some info
It has been discussed many a time and the best place is at the the center of the manifold right below the throttle. Most manifolds have a plug there that can be removed. Mine just had a place to drill. I drilled it and fit a compression fitting in there found at NAPA. If you do a search you will see other's input and some pictures.
Joshua
yebokmj is online now   Reply With Quote
where are you getting YOUR roses?! nahooneyya North West Impreza Club Forum -- NWIC 32 02-10-2009 09:24 PM
OT Homebrewers: Where are you getting your kits? MF-DIF Off-Topic 20 12-29-2006 02:24 PM
Where are you getting your methanol from? NavyBlueSubaru Water/Methanol Injection, Nitrous & Intercooler Cooling 37 11-18-2006 11:18 AM
Where are you getting your tires installed in N. Orange? Drew888 Southern California Impreza Club Forum -- SCIC 0 04-14-2005 09:07 PM
Where are You Getting Your FP Green Hayaboosted Factory 2.5L Turbo Powertrain 7 09-26-2004 03:25 AM
Message Board Statistics All times are GMT -4. The time now is 08:51 PM.
