Old 07-16-2003, 07:40 PM   #1
turboICE
Member Sales Rating: (9)
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default Omori gauge review thread.
Starting this thread for reviews of the Omori line of gauges.
Here is a picture of my WRX-look installed gauges:
And here is my write up of how to use the gallery ports for the oil temperature and pressure senders:
Either here:
Oil temperature and pressure sender installation.
or here:
Oil temperature and pressure sender installation. (PDF)
Questions on installation should be posted in a tech forum. PM me with the URL or e-mail me at [email protected] with questions.
Each of these were purchased from J-Spec Tuning (an Omori USA authorized dealer). Thaison there is extremely helpful and informative.
turboICE is offline   Reply With Quote
Old 07-24-2003, 12:58 AM   #2
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
A bit more on the gauges:
80mm turbo/EGT gauge - very responsive and steady, boost level and EGT are easily picked out driving day or night
52mm gauges - also responsive and steady, sensible labeling to make for quick reading
All of them - great match to cluster lighting
52mm DIN panel - good fit, one suggestion you can make it much cleaner than my hack job if you install from inside the pod from the back of the face area rather than the method I selected from the front.
Old 07-28-2003, 11:37 AM   #3
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Default Re: Omori gauge review thread.
Either here:
or here:
Were is your boost gauge
WRBLUEWAGON is offline   Reply With Quote
Old 07-28-2003, 11:53 AM   #4
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Where did it go!
BTW that should be put in quotes, inside joke - a famous tuner actually asked that question on a dyno.
Old 08-01-2003, 02:18 PM   #5
no_rex_yet
Member Sales Rating: (7)
Member#: 7351
04 330cic
Nice looking setup.
The only issue I've had with my Omori gauges is that they tend to fog up during sudden temp. changes. For example, leaving your heated garage in the winter. The fog will dissipate after about 15 minutes of driving though.
no_rex_yet is offline   Reply With Quote
Old 08-10-2003, 12:51 AM   #6
MikeWRX-NJ
Member Sales Rating: (6)
Member#: 33410
08 wrx
dgm
Either here:
or here:
DUDE THANK YOU!!! x 100
MikeWRX-NJ is offline   Reply With Quote
Old 08-10-2003, 12:57 AM   #7
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Any time Mike, thought I pointed that out at Pruven when we were talking. Wish I had mentioned it then.
Old 08-10-2003, 10:47 AM   #8
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
yea i remember you pointed it out, but that was along time ago, almost 2 months!!!
quick Q: can I just pull the sensor off the front plug and screw in the omori, or do i need that new part?
Old 08-10-2003, 12:13 PM   #9
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I need to rewrite the piece I think because I get that question a lot.
The existing front plug is 1/8 PT (exactly the same as 1/8 BSPT - PT is just the Japanese reference), yes you can just remove the existing idiot light sensor and put either the Omori temp sender or the coupler for the remote sender directly in. The pressure sender that came with mine is a different thread (M10 I think) but the coupler for the remote hose is 1/8 PT. The oil temp sender can be put in directly since it is 1/8 PT.
The idiot light sender is normally closed so that means when the wire to it is grounded the light is on - if you remove the stock sender and cover the stock wire your oil light will not be on at all.
Omori does make an optional 1/8 PT tee which I got but that would not permit the stock sender to remain active but I have not put it on yet since I see no reason with a pressure gauge to have the light.
Ugh, I participated in hi-jacking my own thread. Lets keep this as a product review. Any other tech questions should be put in that forum. If you have questions about the installation PM me with the tech thread URL or e-mail me at [email protected]
So Mike what do you think of your Omori gauges?
Old 08-10-2003, 12:22 PM   #10
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
yes good call.
So far just the boost gauge is operational, but i love it.
I could only find a 1/4 x 1/4 x 1/4 T for the boost (of course I found the proper 1/4 1/4 1/8 this weekend)
I got a length of 1/4 tubing so I didn't have to cut the stock BOV hose.
Over 8k miles and no quivering of the needle. However they do fog up in the rain if the humidity is just right. But it doesn't impeed reading of the gauges, just doesn't look nice. LOL
100% glad I got them. The extra cash for an OEM look was well spent. The oil gauge goes in this week and the EGT will go in when the new turbo gets here. No sense in ripping apart the uppipe twice.
Old 08-10-2003, 12:28 PM   #11
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Thaison has 6mmX6mmX6mm tees with the brass fitting in stock and on his site, order one.
Doh! Just checked he doesn't have the description just the omori part number P-94 - it is a 6mm tee though. I also think I have one laying around, remind to me to look for it if you are ever going to be around JC.
WTT: 45mm EGT omori gauge for 52mm Omori oil pressure gauge (NY) gopsu Interior/Dressup/Audio & Security 0 08-29-2009 11:17 PM
Brand new in Box Omori 52mm Omori Gauges and BNIB Defi Pod 02/03 WRX fej Interior/Dressup/Audio & Security 6 11-30-2007 03:52 PM
What gauge to go w/ the 45mm Omori gauge for '04 mouserWRX Electrical & Lighting 2 12-11-2003 01:51 PM
FS: Omori Gauges/Stock Pod modified for 52mm Gauges WRXerist Private 'For Sale' Classifieds 16 09-19-2003 02:55 PM
omori gauge in stock boost gauge housing? savka Interior & Exterior Modification 1 06-28-2002 08:34 AM
