Old 07-16-2003, 10:03 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Cross Post: Looking for Subaru Tool distributor
I am looking to purchase or rent or some how get my hands on the subaru DOHC valve adjustment tool. Any help would be appreciated.
Joshua
yebokmj is offline   Reply With Quote
Old 07-17-2003, 01:04 AM   #2
smacksube
Member#: 4067
01 2.5 rs
feeler gauges?
smacksube is offline   Reply With Quote
Old 07-17-2003, 05:06 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ouch, that is one tough tool to get a hold of. And DAMNED hard to find a replacement for. Honestly, I have no idea... I've tried our local dealership, they're normally very very good at stuff like that, but they can't even get their hands on them, it seems.
Old 07-17-2003, 08:29 AM   #4
yebokmj
Member#: 2213
Brilliant Red
Default OH NO!
Man I'm really in a bind with this one. When I dropped my heads off to be O-Ringed all the valves buckets with shims were in the heads. When I received the heads back they were all in a box. So that left me with 16X16 combinations. Needless to say I need the tool. If you have the tool can I rent it from you? I will pay shipping and some money to you ect? HELP people I can't run my car.
Joshua
Old 07-17-2003, 02:26 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I don't have it... I actually was in very good with my parts dept. manager here and borrowed it from him when I needed it. They had never even opened the baggie it came in.
Old 07-17-2003, 03:42 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Most service departments have really strict policies about loaning their tools out, unfortunately.
You might want to try Trey Cobb. I know he had to initially source the T45+ torx bit needed for the heads from some oddball place.
Oh yeah, and if you come across the Subaru axle puller, that might be a handy one too
-Jon
Old 07-18-2003, 11:18 AM   #7
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Your probably better off having a valve job done now. The stems will set up higher and the shop can grind the tops down to fit the shims. Shame on someone for not documenting while tearing apart . Cost me $150.00 for the valve job on my DOHC heads.
Good luck on finding that funky tool. I tried a while back. Probably cost $100.00.
Later, Tod
todnar is offline   Reply With Quote
Old 07-18-2003, 05:54 PM   #8
yebokmj
Member#: 2213
Brilliant Red
Default My luck
Okay well I did find the tool and the purchase price is 250 so that hurts the wallet for a one time use tool. I was able to do one side of the engine with the engine out all to proper tollarnces by taking in and out the cams. I am going to try and attempt this on monday working in limited space with the engine in the bay. I might try jacking up the engine in the engine bay to give myself more room to work as was recommended by a tec. How did you find a place that was only 150? Every place I have called is about 500 dollars. This I don't understand since I know what's involved. I have called independents and dealerships. Thanks for the input.
Joshua
Old 07-21-2003, 05:03 PM   #9
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Default ouch
Guess you can rent the tool out to those who need it to make some of your money back.
I called the shop that did my heads today to make sure I was'nt full of it. $150 covered the valve job, check tolerances, and resurface. I know what you mean by being alot invovled because I checked all the specs on everything before I took them. Go figure, just some good Ol' Boys here in Kansas I guess. I'll e-mail the name and # to ya so you can check for yourself. I guess I should'nt pimp them out much until I get the motor together and do some test.
They did get the cam to shim spec to within .0005 or so and the three angle valve job looks good.
Later, Tod
Old 07-21-2003, 08:28 PM   #10
Aphex
Member#: 146
'16 WRX Limited
Todnar, PM me, I need to have my heads o-ringed and am looking for a shop to do it, since I'm KC pretty much every other weekend. Then it would be convenient for me to just take them up there to them.
Thanks.
Aphex is offline   Reply With Quote
Old 11-13-2003, 12:01 PM   #11
Doscooby
Member#: 48327
1998 Impreza 2.5RS
Black Granite Pearl
yebokmj, can you send me the info on where you found that tool I have been looking online for days with no luck.
Doscooby is offline   Reply With Quote
Cross Post: Looking for a Utec answer YourMother'sLover Engine Management & Tuning 8 06-14-2005 08:50 PM
Looking for help/tools on a spring install near Trenton, NJ (Possible Installfest???) TROLL Mid Atlantic Impreza Club -- MAIC 3 06-07-2003 01:01 AM
Cross post: Looking to buy an Impreza for a relative, please help me in my search! Samirr76 Tri-State Area Forum 2 09-01-2001 11:02 AM
Cross post: Looking for good CA dealership AWDrivin Bay Area Impreza Club Forum -- BAIC 10 08-18-2001 01:56 AM
