Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 04-21-2001, 02:20 PM   #1
KEVINL
Member#: 3525
2004 Duramax W/500HP
And Want another STi
Post How do you tell if a SVX oil pump is worn out
I think the SVX's is oil pump is worn out. I start it in the morning and makes unpleasant noises for a couple of minutes which I think that it shouldn't take so long the engine sounds great after its running for a couple minutes. What gives?
Thanls in advance
KEVINL is offline
Old 04-21-2001, 03:16 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
Why don't you ask Robert?
kastle is offline
Old 04-21-2001, 03:22 PM   #3
KEVINL
Member#: 3525
Post
He says its normal which may be true but I wan't second opinions it just doesn't seem right
KEVINL is offline
HTML code is On
How do you tell if a WB 02 Sensor is bad? Krang Engine Management & Tuning 3 05-16-2009 10:14 PM
How do you tell if Oil pump is Primed? Turbo Oil Line? Hayaboosted Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-25-2008 01:55 AM
How Do You Tell if an AFR/O2 Sensor is Broken? williaty Service & Maintenance 4 08-24-2007 08:03 PM
How do you tell if there is an exhaust leak?? silvscorp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-21-2003 12:30 PM
How do you tell if your car is running lean? Sub25RSDTown Normally Aspirated Powertrain 7 09-28-2002 01:17 AM
